Question about GE Washing Machines
I have a ge spacesaver laundry in order for the washing machine to work the dryer has to be running. what is the problem
  • 1,028 Answers
Ck wiring to unit should be 220 volts between 2 outside screws and 110 between each outside screw and middle screw breaker box to be sure breaker is not partially kicked
Posted on Sep 29, 2008
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Jan 30, 2013 | GE Spacemaker Washer and Dryer Electric...
My GE SpaceSaver Washer/dryer will wash, but when it's time to rinse and spin the machine stops. It will not drain, riinse , or spin.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 27, 2012 | GE Spacemaker Washer and Dryer Electric...
Gibson washer wont run after replacing the belt
I was looking for your brand and all I could find was this:
It may not be about Gibsons especifically yet, it's very interesting. Good luck to ya!
Jul 15, 2012 | Washing Machines
1989 (?) GE Spacemaker washer in a park model trailer has a cracked plastic air pressure tank. No model # on washer, how do i get parts.
You do need the model number to order parts...typically on a stacked unit the model number is inside the dryer door
Sep 08, 2011 | GE Spacemaker Washer and Dryer Electric...
Need to replace dryer filter
Most common GE dryer filter
Note: This is probably it but look inside the dryer and get the model number for best results.
Apr 22, 2011 | GE Spacemaker Washer and Dryer Electric...
GE SPACEMAKER dryer working but blowing cool air. what do i do?
check for proper voltage to the machine should have 220 volts if you only have 110 volts it will run but not heat if you have 220 volts you could have a bad heating element
Nov 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Excessive vibrations
I have ordered KE shake away pads. I'll have to see how they work.
Jul 01, 2008 | GE Washing Machines
Washing Machines Logo
62 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
