Question about JVC HD-61FH96 61" Rear Projection HDTV
Tsc tuner I hooked up the ntsc and atsc tuner to a uhf antenna to get the off air hd signals but the tuners go through the process of scanning and find only a few channels and none of the digital atsc channels. Is there any way to test the tuners or replace or repair them? The TV plays beautifully on the composet red white and yellow from the bell express satalite but shows green picture on the component red green blue. Does the TV need to be repaired?
2 Suggested Answers
Taisha
  • 44 Answers
SOURCE: 52G786 ATSC Tuner no longer works
I have the same exact model tv...Love it...ATSC tuners is in definition an Analog tuner. As the broadcasting companies change over to Digital broadcasting before the deadline in Febuary 2009 more and more local or Non-Digital chanels are becoming obsolete. You would have to purchase a converter box for your tv if your not planning on getting cable. Another way to gois if you have an old cable line running through you house (no incomming cable) plug you tv into that jack. That also acts as a antenna. The sweet part of all this is that your tv do have a QAM tuner or Digital tuner built in just need that digital antenna to pair it up.
Posted on Jan 03, 2009
Trying to convert from cable to antenna...I get no signal and it seemingly goes into sleep mode
Consult your TV's owner manual and enter "set up mode" to switch the RF or Antenna input from: CATV / Cable to: Antenna / Off Air. Then, allow the TV to scan VHF & UHF for signals strong enough to "tune in". You may need to upgrade your antenna in order to collect enough signal to display video properly. Make sure that your TV has a digital tuner (ATSC) as the old analog tuners (NTSC) have no signal to tune since broadcasters were forced to digital transmitters by the FCC years ago.
Use the site linked below to help you select an antenna that will allow you to receive all signals possible at your location - without buying more antenna than you need.
Like AntennaWeb org
Apr 08, 2015 | Televison & Video
RCA HDTV antenna is it Ok on a non HDTV
Yes, this antenna will receive VHF and UHF signals. If you install it properly outside and point it towards your local transmitters, it will work nicely (use tvfool.com for the directions to your transmitters). The "HD" label is something of a marketing gimmick; the tuner on the TV will pull in the signal and interpret ito display on your TV.
However, make sure that you have an ATSC tuner for your TV. Only a few low power NTSC stations are still broadcasting.
I hope this helps.
Apr 15, 2013 | RCA Televison & Video
Tried to hook up a HD antenna but it won't work
HD is pretty critical and if a indoor antenna do not expect much or anything for that matter.
Jun 17, 2012 | Televison & Video
It's staying on 480i sd why not 1080i
There's only one way to get that TV to switch from 480i (which is an SD or Standard Definition signal) - that's to provide it with an ED or HD resolution signal (a 480P signal is often called ED or Enhanced Definition while 720P, 1080i and 1080P signals are called HD or High Definition).
The old standard yellow composite video cable.
You will not get ED or HD signals through the old composite RCA phono jacks (usually yellow in color), either. You'll need to use an RGB (red, green and blue) component video cable, HDMI cable, DVI, or other type supported by both your TV and the video source (CATV box, Blu Ray disc player, Satellite converter, etc.). More on this, later.
RGB cable.
An HDMI cable - this provides Digital audio signals, too.
A DVI cable.
First, you'll need a source capable of sending ED or HD signals. This can be a progressive scan DVD, Blu Ray player, HD Cable or Satellite converter, or a simple TV antenna. Not all DVD players are capable of the 480P progressive scan output - it must be labeled as such. The DVD movies are not labeled progressive scan as they all will play back at 480P if played in a DVD player capable of progressive scan, otherwise they play at 480i. A stand alone Blu Ray player or one in the Sony PlayStation 3, the older HD-DVD in the Xbox360, (it is important to note that the Nintendo Wii can output either 480i or 480P signals only when connected with their special component video cable), "set top boxes provided when you choose HD service from your local cable provider or satellite TV provider are the main sources for signals better than 480i. As mentioned above, the old standard yellow video jack is not capable of supporting signals better than 480i. You must use the HD jacks and cables between to get these signals into your TV.
The Wii 480P cable assembly - includes stereo audio, too.
Lastly, if your TV has an ATSC tuner (it is not uncommon for it to have an NTSC tuner and CATV tuners as well), you can input a UHF antenna directly into the the antenna terminals on the TV. Broadcasters in most areas have been moved into UHF bands - but some areas have one or two that operate in the VHF bands still. Check antenna web for information and help selecting antennas and broadcasters in your area. The nice thing about the antenna method is that no other cables, converter boxes, etc are needed to enjoy HD signals - plus - they're free!
Just remember you need a source capable of ED or HD signals and a way to get those signals to your TV. The yellow composite cable is from days ago and only passes 480i signals.
I hope this helps and good luck! Please take a moment to rate my reply - thanks!
Feb 16, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Initial scan only finds 20 analog channels and nothing else.
What type of antenna do you have and is it pointed at the transmitters? Use antennaweb.org or tvfool.com to check your antenna type and direction for your location. Antennaweb is very conservative in the channel listing even though the site assumes an exterior antenna. Tvfool lists the channels and the respective antennas with a color code that matches the manufacturer's labels for the antennas. Tall trees and buildings can block the signal.
Digital signals are either on or off for the tuner (either there is enough signal to process or no signal). Are you sharing the antenna signal between devices? An amplifier may help.
If you are using an antenna that is pointed correctly and should receive the stations around you, then the problem may be the ATSC tuner. This is on the same board as the NTSC (analog) tuner for most TVs these days.
I hope this helps.
Dec 24, 2010 | Vizio VW42LF 42 in. LCD HDTV
How do I get the HD on this model? Which cables/hook up should I use? I do not have a cable box or set top box but if these are required, please let me know. Thanks!
Your unit is HDTV ready but is not an HDTV. It is capable of displaying HDTV only through the component inputs. Your tuner is analog NTSC and will not receive HDTV or digital.
You could get an HDTV picture using a Blue Ray DVD and hooking up the component connectors from the DVD to the TV.
The only other way would be to get an HDTV tuner with a component output and hook it up the same way, component out to component in, and hook the tuner input to an off air antenna (receiving HDTV) or cable or satellite with HD signals.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 21, 2010 | Sony KP-51WS510 51" Rear Projection...
Attenna hook up
Yes, This set does not have a digital tuner built in. All over the air signals are now digital. This set will work without a converter if hooked up to standard cable,DVD,VCR or Video game console. If you purchase a DVD with a digital tuner built in you can skip the converter box and hook your HDTV antenna directly to it.
May 06, 2010 | Symphonic ST4919 19" TV
Digital tuner not picking up signal
If your trying to get digital stations over the air with a standard ntsc tuner it will never happen. The set must be equipped with a ATSC tuner, that's the one that will receive digital signal over the air. (not cable) If you have the tuner in that model then the signal must be very good or it will display "no signal". Give me a model # quick and I will do the homework for you now.
Apr 15, 2009 | Televison & Video
Does anyone know if this tv is analog
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
No HD
Your TV has a built in tuner but NOT a built in antenna. Depending on where you live (distance from broadcasters) you will need to add anywhere from rabbit ears (with the UHF loop) to an antenna on the roof or mast.
If your home already has an antenna installed, connect the coaxial cable to the back of your TV. Then go to "Set-up" and scan for DIGITAL channels. If you are trying rabbit ears, do the same.
Mar 15, 2008 | Protron PLTV-4250 42 in. LCD Television
JVC HD-61FH96 61" Rear Projection HDTV Logo
37 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
