Question about Hobart A200 Stand Mixer
A 200 T grease leak & gear noise
I have an a 200 t. I have noticed a small dollop of black grease leaking from under the planetary part, where the attachments go, from what looks like a cap of some sort. Also, I can hear what I assume are the gears spinning. Do I need to re grease? Is there a gasket missing? Thanks
  • 640 Answers
The o-ring on the attachment hub gear is wirn causing the leak.If the mixer is old it wouldnt hurt to change the grease.
Posted on Oct 01, 2008
4ksm50pwh leaking oil
Remove the chrome drip ring, knock out the planetary pin and remove the planetary. Clean everything you have taken off with a rag or tissue, pop a small amount of grease on the teeth in the underside of the motor housing and reassemble. That's an easy fix that will last a reasonable time. The problem is the grease in the gearbox is getting old and breaking down. It is food grade grease so what leaks is harmless to you. Eventually you will need to replace the gearbox grease but that's an involved dirty job.
Aug 02, 2013 | Food Mixers
Kitchenaid mixer leaking oil
Get a copy of the Repair Part List for your model at Kitchenaid.com
Grease inside the Planetary Assembly (the shaft is tight fit to the Planetary
plate at the factory and is not designed to be taken apart, so do not use
any hard object such as a screwdriver to separate them) over times can
turn to liquid and leak down the bowl. Removing the Planetary assembly
and adding Kitchenaid Food Grade Grease is not a task for a novice.
To properly remove the Planetary Assembly, you must work from inside
the Transmission Housing: Remove in this order: Retaining Clip(25), Bevel Gear(21),
Retaining Pin(18), Worm Follower Gear(19). Use a soft mallet to tap out the Shaft
of the Planetary Assembly(15). Re-assemble it in the reverse order.
Note: The Bevel Gear is extremely tightly fit on the shaft, and a pin punch
must be used to remove from the shaft.
Jul 14, 2011 | KitchenAid KP2671 Professional 6 Series...
Leaking oil
There are only two places where Food Grade Grease is used: In the
Transmission Housing (normally installed with a gasket) and in the Planetary
Assembly (Agitator gear). Over times, the grease will get hot and turn into liquid.
The Beater shaft has an O-ring to prevent oil from leaking down, but there is
nothing to prevent oil from the Planetary from making its way down your mix.
Depending which model you have, it's time to open up your mixer, clean out
all the oil and replace it with fresh Kitchenaid Food Grade Grease.
Jun 25, 2011 | KitchenAid Food Mixers
I have a KSM90 that is about 8 years old. It started leaking oil and the top of the mixer goes down into the bowl too far and it 'drags' the attachment along the bottom of the bowl and makes a generally...
It sounds like the Planetary Gear assy. has gear lubricant leaking into it from the gear case above it. This may not be that unusual so there may be 2 possibilities or a combination of both. The Gear Case is directly above the Planetary Gear assy. It is filled (sort of) with a food grade (assuming...I hope) grease that is necessary to keep things lubed. There are fiber washers and possibly an o-ring in the shaft assembly which should keep the grease from migrating toward your food. The Planetary Gear assy. is the part that rotates around on the business end of the mixer. It has a bronze bearing that is intended to run without lubrication. However it is a wear point and if worn sufficiently, could allow escape lubricant from the gear case above to drip into your mix. The Kitchen Aid Service Manual is a good source of info. You can get it as well as complete diagrams of the internal parts at:
http://www.goodmans.net/get_item_ka-4162075_kitchenaid-mixer-4162075-planetary.htm
You can also get parts and the KitchenAid Service Manual.pdf at:
http://www.mendingshed.com/kitaidparts.html
I know if it was my mixer, I'd give it a look. They're good tools and worth the effort!
Good luck.
DZII
Jan 02, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Making noise in planetary gear area. we have a l 800 hobart mixer just purchased ,has wirring noise planetary gear area ,i 'm quite sure it is common wear from use , but want to repair...
The noise you are describing sounds like the noise associated with the pinion gear meshing with the ring gear in the planetary. Depending on the age of the unit, some noise is to be expected. The lubricant used in the planetary is different than that of the main transmission and is not visible without disassembly. Again, depending on age of the mixer, your planetary may have a small amount of oil and a pump to bathe the gears or just a generous amount of grease applied to the gears. The only way to properly inspect the planetary is to remove it. Depending on your luck, this may be 20 min job or several hours. It all depends on the ease of which the planetary releases from the main center shaft. Should you decide to tackle this job yourself let me know and we'll do our best to assist you. Several knowlegeable techs monitor this area of the site.
Sep 13, 2009 | Hobart P660 Stand Mixer
Lubricant leaking from planetary gear
use a lithium based gear grease
May 24, 2009 | Food Mixers
Hobart A200 noise
Your mixer was built in 1942 and from the sound of it, it's been without grease for some time. Before you dismantle it, try adding new grease to it. This is the less expensive and less time consuming approach. The grease product to look for is Shell Darina XL EP-2, Try to find a local Shell Distributor and see if they'll sell you about 4 tubes of 400 grams each. This grease is compatible with most other greases, so you won't have to remove the old grease before you add the new stuff.
Remove the four screws that attach the Hub to the body of the mixer, pull off the hub. You now have access to the transmission area. work the new grease into the cavity, try to get as much grease as you can toward the back of the compartment. This will be a very messy job unless you have, or acquire a grease gun that the tubes will fit in. Lay the mixer on it's back and let gravity help you to get a lot of grease down through the hub opening. Keep adding grease until you've greased up to the hub opening. Grease the hub gear and then re-install the hub. Raise the mixer to vertical and start up the mixer, letting it run for a couple of minutes. Stop the mixer and shift gears,, once again start the mixer and repeat this procedure for the last gear. Listen for the sounds it was making before, they should be silent or at least muted. If it's still making loud noises, You may well have to take it apart for an overhaul. Dont overlook the planetary gearing, this gearing is not bathed in grease like the trans. Remove the planetery assembly, clean and inspect the planetary gear and the large ring gear in the mixer body. Regrease both and re-assemble. Your mixer is now as quiet as it will get short of a complete overhaul. If this solution works, it has only cost you a few bucks and a bit of time, making this. solution a good one, unless you still have the major noise issues.
I f you've found this solution helpfull, please rate it and Good Luck! ricardok45
Nov 26, 2008 | Hobart A200 Stand Mixer
A-200 mixer oil leak
the trans uses all grease today hobart uses mobil lith aw-2 you can get the seal from any hobart office.
Oct 19, 2008 | Hobart A200 Stand Mixer
Oil leaking
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Sep 30, 2008 | Spar SP200 Commercial Planetary Stand...
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
198 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
