Question about Lexmark X8350 All-In-One InkJet Printer
Lexmark x8350 scanner started hanging up on the left side, makes chattering noise
  • rickmcsb Dec 01, 2008
    I removed the back panel and all were seated properly seated. Is there another solution to this problem?
  • scm74 Feb 03, 2009
    After 2-1/2 years of hassle-free use, mine is doing the same thing. I too opened the back panel as suggested and didn't see anything loose. I'd love to try and check underneath the glass, but I can't see to figure out how to pop the plastic out. Help! Would prefer to not spend money on fixing this if it's something I can do myself.
In the back of the printer is an access panel with one screw to hold it in place.
The outer side edges are held in place with it plastic tabs (which you can not see due to they are inside the printer. So carefully remove this panel without breaking the tabs. Look inside and you will see a ribbon connecting to a circuit board. This is probably loose or disconnected. The end of the ribbon is hard and not flexible. Push the end of this ribbon in the white plastic standoff slot. This ribbon sometimes comes loose when the top scanner cover is partially remove from the printer. I said, partially because if you needed to remove the top scanner completely, then this ribbon would need to be completely disconnected. You can also see, when the access panel is off, other wire connections connected to this circuit panel. Sometimes they also come loose or disconnect when the top scanner is partially remove. Connect them if they are loose or disconnected. I believe to solve your problem is the ribbon disconnected. Best wishes in solving your problem.
Posted on Oct 10, 2008
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
Corvette makes a distinctive 'clunk' when engaged in gear and starting to move forward or back. Chattering in left rear hub when making left hand turn. Rear suspension and all brake suspension...
The two symptoms you posted may or may not be related. I'd check the driveshaft and axle joints for any looseness or binding. (do this with the rear wheels hanging free in neutral, front wheels blocked)
The chattering may be an axle joint or the posi unit in the differential. Most times replacing the diff lube, (using posi additive) then making tight left and right circles will free the clutch packs.
Difficult to diagnose noises online. If you have any problems finding the source, have an experienced tech look at it,,,You still have the option of actually doing the work itself.
May 28, 2011 | Chevrolet Corvette Cars & Trucks
On my X8350 scanner/printer, I can't figure out how to scan to a file and I can't find my manual.
The manual for your printer can tell you all you need to know. It can be found here:
http://www.lexmark.com/publications/pdfs/8300/eng/ug.pdf
Regards
Apr 07, 2011 | Lexmark X8350 InkJet Printer
Where I´can finde a driver
You can download the Lexmark X8350 driver from the Lexmark website for free. Use the Vista driver in Windows 7. First, check if your computer is running on 32-bit or 64-bit system type. Go to Start menu-> right-click on Computer -> Properties. Take note of the System Type.
Download the driver using the link below: Download, execute the file and follow the instructions on the software. Hope this helps. Thanks.
Jan 20, 2011 | Lexmark X8350 All-In-One InkJet Printer
Lexmark X8350 "communication not available"
I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
Jun 02, 2009 | Lexmark X8350 All-In-One InkJet Printer
Lexmark x8350 printer voice notification
hi try this...go to start- all programs-lexmark X8300- lexmark solution center ,
on the solution center page click on the last tab on the left hand side...u have an option for the voice notifications...
Feb 09, 2009 | Lexmark X8350 All-In-One InkJet Printer
Scanner
Try scanning from the image software you are using, not from the front panel buttons. Go to the TWAIN options and make sure your scanner is selected, then go to Acquire and the scanner software will start. Scan from there without using the scanner front panel.
May 05, 2008 | Lexmark X8350 All-In-One InkJet Printer
Scanner won't scan
Right Click on My Computer/Computer if Vista........ Click on Properties then click on Hardware click on Device Manager...... On that list u will see the Printer Name with an exclamation Mark........ Right Click on that click on update Drivers...... Insert the CD to the drive....... Select Browse My Computer for Driver software..... Click on Browse and then Double Click on Computer go to Lexmark X*****.......... Double click on Drivers and then click on scan and then click ok........ Now click next it will say the hardware is ready to use then u can just click on finish and scan..... Thanku
Apr 15, 2008 | Lexmark X8350 All-In-One InkJet Printer
Lexmark X8350 All-In-One InkJet Printer Logo
151 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
