Question about Casablanca Fan 38DH32T Bel Air® Halo Weathered Copper Ceiling
Casablanca Fan 38DH11T Halo w/InteliTouch Problem: fan works,lights do not.
I have a 2 year old fan (above) that worked properly for about 18 months, then , about 6 months ago the Inteli-Touch would work the lights and fan only intermittently. During the last 4-5 months, the fan works properly, but the lights do not work at all. When the fan is on, a low "moan" comes from the housing when I push the light button.
I have replaced the W-32 Wall Control Inteli-Touch device but the problem remains.
The "Test and Demonstration Program" just puts the fan on speed 6, period. The "Light Minder Program" does nothing.
Any suggestions short of replacing this pricey turkey?
  • Anonymous Dec 29, 2008
    Casablanca inteli-touch fan/light. When power switch it pressed, the fan comes on full speed and can not be slowed or turned off . Lights work and dim properly.
    Nel in Texas
  • 57 Answers
SOURCE: The Intelitouch wall control operation is
Your control is malfunctioning. If the fan will sometimes operate normally, it is not a problem with the board in the fan. The replacement control is $50~ through Casablanca, but you can find them on ebay for half that cost, or less. Depending on your model of fan you may have the W-32 control, or the W-33. Most likely you have the W-32, but, reply with the model # and I'll let you know which control you have.
Thanks
Posted on Apr 01, 2010
Hi, My maytag bravos dryer is one year and 2 months old. Suddenly it has stopped drying the clothes, it takes forever to dry a load and clothes are very warm and wet, lots of steam in the dryer, also the...
Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
Jan 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Extreme rumbling,vibration have it apart whats the best way to tell if the drum is out of round or the rollers are shot have cleaned vent and motor. motor runs smoothly on its own
You rotate the drum rollers looking for an eliptical outer surface rubber of the rollers. Also make sure the rollers do not teeter fore and aft on the roller shaft.
Next grab the idler pulley for the belt and see if there is any play in the ldler.
Worn drum felts / gaskets or a front bearing glide can also contribute to the problem
See this link for parts:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47834&diagram_id=28471897#d28471897
Item numbers you need to check are
6, (unusual wear)
14, drum gaskets {2 ea front and rear} (torn, worn or folded)
18. Just replace the belt if your into it this deep..... especially if the dryer is +5 years old
23, (roller Shaft for wear)
24, roller for wear center and outside surfaces
30. Drum glides (Kit)
A rumble is usually associated with a bad fan blade...as in the center of the fan blade hub is cracked or broken. Check the fan for play.. also hold the motor drive pulley and see if the fan rotates on the motor shaft. It should NOT rotate without turning the drive pulley
A squeal is associated with the belt or idler pulley
A thump is a drum/felt/roller/glide problem.
Thanks for choosing FixYa,
Kelly
Jan 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Ge electric dryer. suddenly stopped working. Will
Hi Stv,
There isn't really major problem, but a problem.
You will need to unplugged your unit and take it apart. Are you handy?
If and when the unit is apart look at the motor and the fan exhaust and see if there is a coin or screw is jamming the motor or the fan
while you are in there you may want to clean it up,
That should be the problrm
Jul 25, 2010 | GE DBSR453EBWW Electric Dryer
Compressor won't start. Roper refridgerator, fan runs, lights work, compressor won't kick on. ~ 6 - 7 year old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Dec 13, 2009 | Dryers
Thermal Fuse keep failing
Fuse and element failure is related to lack of air passing over the element. The drum and fan should run even if the heater is inoperative. Find out what is stopping them, then work on heat. If motor is running, there should be air flow--pull vent hose from wall outlet--should be brisk air flow. If not, remove the lint screen and check again. If now ok, soak the lint screen in hot water and detergent. If drum does not turn, check the drive belt and if it sits properly on motor pulley.
Aug 01, 2009 | Whirlpool LER5636P Electric Dryer
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Jul 24, 2009 | Asko T721 Electric Dryer
Dishwasher doesn't turn on at all
fan fail safety switch
over heat safety switch
machine power switch
burnt out power cord test these first
Jul 19, 2009 | Kenmore 60172 Electric Commercial Dryer
Stink Smell from Electric Clothes Dryer/Fuse Box
this should be quite easy to solve.remove the circuit breaker and sniff it. if it is the same smell you are getting when the dryer is running that is your problem.have an elecrtician check and replace with correct value.the dryer is most probably running on an overloaded circuit.
Jan 07, 2008 | Dryers
Intermittant heat for drier
check for flow of air through the dryer arts as it sounds like the clicking is the thermal cut out activating, this prevents the dryer from overheating, the common cause for overheating is blockage (no air flow) or the fan that blows the air round the machine is not working, or not working properly, so check the fan see if its turning etc hope i have helped, if so please rate me
Oct 03, 2007 | Dryers
Casablanca Fan 38DH32T Bel Air® Halo Weathered Copper Ceiling Logo
287 people viewed this question
Top Casablanca Fan Dryers Experts
 Jack Jr
Jack Jr
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
