Question about Tokina 12-24mm f/4 Pro DX for Nikon
Back Focus Issues on Tokina 12-24 with NiKon D300
My focus seems to prefer 7 feet instead of infinity. It seemed to work OK when I first got it, but now all of the shots are coming out a bit soft when using autofocus. It never goes into the infinity range, stops just short of it. I have 2 D300's, and it does the same thing on both cameras. Any ideas?
4 Suggested Answers
  • 37 Answers
SOURCE: Nikon TC-17E II with Nikon 70-200mm f/2.8
You may have a dirty contact on the tc cpu pins. Try cleaning the pins with a clean pencil eraser or some methanol. You could also have a loose connection between the tc and the lens or body. Try applying a rotational force in both directions...see if you notice any change in behavior. If you have a local shop, see if you can try another copy on your lens.
The 17e may have slow-ish performance in low light, but it should still be usable. If neither of these issues is apparent then it may need to be exchanged or serviced.
Posted on Jan 25, 2008
  • 111 Answers
SOURCE: Does Tokina-12-24mmF/4Pro DX complies with Nikon-D3 FX Format
Barrel distortion like you describe can always be a problem, especially at ultra-wide focal lengths like yours at 12mm. Some of this can be compensated for in software... Adobe Photoshop CS2 and Elements do a reasonable job, IMO, Bibble Pro ( does even better, especially with the 3rd party plugins like Percy perspective correction. These are things we have to live with when we have smaller sensors and ultra-wide angle lenses. There is nothing wrong with your lens, you will probably find that this distortion is minimized if you use a longer focal length (say 14mm) and/or stop down the lens a bit.. try f8, wide angle lenses have huge depth of field.
Posted on May 20, 2008
  • 3006 Answers
SOURCE: I just bought the Tokina SD 12-24 F4 (IF) DX
Only the MkII version of this lens has an autofocus motor built in, the MkI relies on a motor in the body of some Nikon AF SLRs to autofocus. The D70 does not have an inbuilt AF drive motor, so if you have the MkI lens then you can only use it in manual focus mode on your camera.
Posted on Aug 05, 2009
Autofocus not working
Have you tried to see if you camera is running the latest firmware? If its not update it.
Jun 12, 2016 | Nikon D Cameras
I just bought a Tokina 100mm f/2.8 AT-X M100 AF Pro D Macro Auto Focus Lens from B & H and put it on my Nikon D300. When I press the button a blinking FEE appears. What seems to be the problem?...
The FEE error indicates that the camera cannot control the full range of the lens aperture. If your lens has a mechanical aperture ring, rotate the aperture to its smallest opening, or highest f-number - normally marked in orange. Select this aperture and lock it using the aperture locking switch to prevent this message from appearing again.
Dec 18, 2010 | Cameras
Did the sigma 75-300 dl will work with nikon d300?...i mean the auto focus and matrix focus
Yes. The D300 has a focus motor built into the body and thus does not need one in the lens. The lens will also meter properly with the D300.
Aug 10, 2010 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
Which size of adapter to use to fit it to Nikon D300?
Nikon bodies are thicker than Olympus bodies, thus while Nikon lenses can be made to focus to infinity when mounted onto an Olympus body, an Olympus lens will not focus to infinity were it mounted onto a Nikon body. Thus, no one makes an adapter to fit an Olympus lens onto a Nikon body.
Jul 01, 2010 | Olympus Normal Zuiko 50mm f/1.2 Manual...
My 70-200mm f/2.8 VR lens is having focus issues. when I press shutter button to focus, the lens jerks in and out of focus. Can't focus on any objects very well. I do use a TC with it and also recently...
Jul 12, 2009 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
Back focus
That's not likely to be the camera but the lens. You can actually set a focussing pre-set for each lens you use on the D300. See your manual for more info.
Jul 04, 2009 | Nikon D300 Digital Camera
Nikon D300 camera body shutter doesn't always work
Perhaps it is a focusing problem- try it on manual focus setting to see if the problem still persists...
May 05, 2009 | Nikon D300 Digital Camera
Will Nikon D300 focus with the 11 point AF11 setting?
You may want to consider fine tuning the lenses. I understand that you want the shallow depth of field, but the lens is sharpest at the middle f stops. What is the comparison between a stationary object like an apple or grape (something with a circular shape). I understand you have a higher shutter speed, but the small movements of a person could cause variances in a single focus mode. Are you using the half-shutter press for focus or the AF-E button? Tripod? Remote shutter release?
I asked about the distance relative to the lens length because the DOF can really change based on this. I have found this recently with my macro work so I wanted to find out if you have experimented with this or fired a bunch of shots at a single setup.
Apr 27, 2009 | Nikon D300 Digital Camera
Problem shooting portrait
That's just the quirky autofocus of the d80. Try tilting the camera diagonally to focus and tilting back up to shoot.
Unfortunately, autofocus issues like those are the difference between a d80 and a d200/d300 :/
Mar 20, 2008 | Nikon D80 Digital Camera with 18-135mm...
Tokina 12-24mm f/4 Pro DX for Nikon Logo
554 people viewed this question
Top Tokina Cameras Experts
Are you a Tokina Camera Expert? Answer questions, earn points and help others
