Question about Sony Walkman Bean NW-E307 MP3 Player
Sony walkman mp3 player
My sony walkman mp3 player was washed along with my laundry. It won't power on . What can I do?
Take it to a sony store. tell them your problem. then for a fee they will replace sum stuf nd er u go it will wurk agen
Posted on Dec 06, 2008
How to open the file on the walkman
I have a similar model. The file itself needs to be the correct format, otherwise it won't open (this is a limitation on the software/encoding etc). However, once the file is on there, plug in a mini usb, access the walkman through your computer, then open it up that way
Sep 29, 2012 | Sony Walkman NWZ-S616F MP3 Player
Sony Walkman NWZ-B162F MP3 Player won't turn off
I was also facing the same problem, and while going with some hit and trials, was able to find a solution for this as following: power can be switched off by holding the main key for long, the key which is used to select the folders, that is, the center of navigation key. Hope it helps.
Jun 13, 2012 | Sony Walkman NWZ-B103F MP3 Player
Sony walkman Sony Walkman Bean NW-E305 (512 MB) MP3 Player won`t charge
Good morning, afternoon, evening or night; whatever time of day you are reading this solution post. Thank you for choosing FixYa to assist you with your problem. Your Sony Walkman Bean NW-E305 (512 MB) MP3 Player won't charge properly? Well Danish, we must use a method called troubeshooting to figure out and solve this situation. There are several reasons why this player may not be charging properly. The cause is either coming from the battery inside of your MP3 Player, a bad or faulty USB cable connection, or something (software) isn't installed correctly. Let's look at the first cause- The battery. The battery life may be gone. If it is, you will need to replace it if possible. Your device takes a
Sep 26, 2011 | Sony Walkman Bean NW-E305 MP3 Player
My sony walkman NWZ-E443 shows power source battery 0.why?
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 02, 2011 | Sony Walkman NWZ-S616F MP3 Player
Cant play back tracks no data
Did you add songs to it yet? To add songs to it plug it in the your computer and import the songs to it. If it still won`t work rebuild your data base. Doing so well factory reset your Walkman and fix any bugs in your Walkman.
Jul 17, 2010 | Sony Network Walkman NW-E005 MP3 Player
Cnt copying
if i am not wrong u cant do drop and drag songs in sony walkman series...bcoz along with u r walkman..there s a driver cd..ok..u should install the software wch s supporting u r walkman...then using that software u can send songs to u r set and even u can delete songs frm u r set...its safe to use this software..bcoz drag and drop option s always leads to damage of u r walkman bcoz of infected files...its the same hw the i-pod works...even in i-pod u cant drag and drop songs into it!!!
Jul 24, 2009 | Sony Walkman NWZ-B135 MP3 Player
Nwz-s515 won`t charge
Check for a reset option somewhere in the software, if after reset (or if there is no reset option) it still does not charge then the battery has died. You can call Sony for repairs, it may be under warranty still. If it needs repair head over to Sony's website for repair at:
http://eservice.sony.com/webrma/web/index.do
Jun 25, 2009 | Sony NWZ-S615F Walkman Video MP3 Player
My walkman is dead
shops don't give warranty on mp3 players more than 2yrs max. and even if it still were in warranty, the warranty would've been void when the player got washed and tumble-dried.
try removing the batteries, letting it dry for a few days and using new batteries afterwards. if this doesn't work, the mp3-player is done for...
May 25, 2009 | Sony Network Walkman NW-E005 MP3 Player
Problem with Sony Walkman NW-S705
This is because the player does not recognize tracks that havent been uploaded by Sonic Stage(You might have a CD of this software along with an mp3 player)
Jun 21, 2007 | Sony Walkman NW-S705 MP3 Player
Sony Walkman Bean NW-E307 MP3 Player Logo
125 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
