My Go Video 32" flat screen HDTV will stay on for 5 to 10 seconds then shuts off!
At first my tv would cut off a few times after being on for about 5-10 secs then I get up and turn it on using the tv's on/off switch. (remote controls power button didn't work for this problem) after maybe 5 go rounds it would stay on but eventually it got to the point where it would not stay on for more than 10 secs at all. (Even after 20+ attempts) It seems like its trying to get warm in order to stay on but it won't stay on long enough to get warmed up. (I'm guessing)
Its a fairly new tv that we got from a rental place and for the first 6 months it worked fine and then slowly started developing this problem. I noticed in the begging when I would turn it on and off quickly the tv would stay on, don't know if that helps diagnose the problem but anything you suggest would help.
Thanks
  • 1 more comment
  • ms quinn Sep 29, 2008
    I have the same problem with our 32 inch Hyundai LCD. In order to get it on again I have to keep hitting the reset button on the back of the TV and hope eventually, after many, many attempts, it stays on. It's simply a matter of 'hit or miss' since I have no idea what's causing the problem, nor do I know what to do to stop it. So, any help resolving this would be very much appreciated at this time.
  • Anonymous Mar 09, 2009
    Like my Proview lcd 32 wide wont stay on ether, it worked fine for a month or so then it cut off and when i turn it back on it cuts right off, but it says its on but there is no picture
  • raywygo Apr 22, 2009
    This has happened to me also, my video cuts out after a while but the audio is still there. And everytime I turn it back on it cuts out quicker
I had the same problem its not tht it needs to warm up to stay the problem is its geting to hot take back cover off an mount a small electrical fan facing the power supply an make sure the fan is on an blowing cool air towards the board an then turn the tv on this should fix ur problem i done it to mine an its been working fine ever since an its been two years
Posted on Aug 24, 2014
I have the same exact problem with my Go Video 32" HDTV. Yesterday the power stayed on for several hours, now it wont stay on for more than 5 - 8 minutes.
Please someone help!
TJ@streetkidssoftball.com
Posted on Nov 02, 2008
Why does my vizio tv only stay on for a few seconds before the picture goes fuzzy and the tv makes a very loud screeching noise and shuts itself off
Sounds like the power supply board has gone out. It can probably be replaced, but only by someone qualified to do so.
Oct 21, 2014 | Vizio L32 32 in. LCD HDTV
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Emerson lc320em9 wont stay on, why?
I would suspect an issue with the power supply board, maybe even puffed up filter caps on that board---that is the place to begin.
May 16, 2012 | Emerson LC320EM9 32 in. LCD HDTV
Emerson LC320EMX stays in standyby mode
one of the transformers has an issue which is very common for that model. You can get a replacement inverter from www.tvrepairworld.com
Mar 31, 2012 | Emerson LC320EMX 32 in. LCD HDTV
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
CVizio 32" background lamp won't stay on
Ur backlight inverter ic board is dead must be replace.
Aug 31, 2009 | Vizio L32 32 in. LCD HDTV
Emmerson HDTV f32
The failure with this LCD might be due to a failing power supply or backlight inverter board. Since your TV is less then a year old, I would suggest to call the manufacturer to get it fix under warranty.
Good Luck.
Jan 17, 2009 | Televison & Video
Element hdtv flx3210 shuts video off after a few seconds.
Send the set back for service.
The power supply most likely failed, or another circuit board has failed and the set is in the protect mode.
I would consider to see if the dealer would exchange the set for a well known quality brand name set and pay the difference.
Jerry G.
Jul 11, 2008 | Televison & Video
Televison & Video Logo
425 people viewed this question
Top Televison & Video Experts
