Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
I dropped my Nuvi 360 GPS and the screen now displays horizontal colared lines and the graphics will not appear.
  • Garmin Master
  • 2,124 Answers
From technical experience, this indicates a broken display or display ribbon cable having become disconnected from the unit being dropped. The unit will have to be opened up to determine if the cable is loose or if the display has been damaged. The only way to determine if the display is bad is to substitute it with a known working display.
- Jim
Posted on Sep 29, 2008
I have 5 white dotted lines running horizontally across my nuvi1490lmt. Does anybody know why this would be?
Yes, this is caused by a defective LCD display, There is nothing that you can do to make them go away. It is caused by a defective transistor in the LCD display logic that is either stuck on or off. The transistor controls a single horizontal line across the screen. The only way to fix this problem is to replace the display.
http://www.sharc.net/gps_LCD_repair.htm
Oct 26, 2013 | Garmin nuvi 1490T GPS Receiver
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
Two horizontal white lines on top of display and one yellow line vertical trough display
Any lines on the screen that are not supposed to be there is an indication of a defective LCD display.
Jul 15, 2012 | Garmin nuvi 1450 GPS Receiver
Touch screen not responsive after speaker replacement It worked before speaker replacement.
To calibrate the touchscreen on a nuvi 300 or 600 series:
1. Power the unit On.
2. From the Where to? / View map screen, touch Settings (wrench icon).
3. Touch Display.
4. Touch Recalibrate.
5. A new screen will display that says Press Dot.
6. Touch the center of the dot.
7. Keep touching the center of the dot as it moves around the screen.
8. When Calibration Complete appears on the screen, please touch OK.
The touch-screen will now be recalibrated.
Nov 04, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Gps screen has a black eye
The LCD display needs to be replaced. Please see this link:
- Jim
Aug 05, 2009 | Garmin NUVI 360 GPS Receiver
Nuvi Screen is messed up
Sorry to say but your screen is most likely damaged. You should never store a LCD display in the cold. First, the cold slows down the screen's response time... after all.... LCD stands for Liquid Crystal Display.... what does "liquid" do when it's cold? Also, there is a chance that condensation develops inside from your car being cold and then heated when you drive it. Not good for electronic devices.
The screens can be replaced.
- Jim
Nov 16, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Touch screen is cracked on my garmin c340
Yes. Please email me at ks3r at sharc dot net and I'll quote you a price to repair it. I have repaired many Nuvi's with this problem. I have references.
- Jim
Jul 15, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Display problems with nuvi 260
You may have to send in for service. A bad screen normally is not a good sign. Sorry.
If you are sure that the updates have been downloaded your only other option is:
Trying a full master reset:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 260 series device: Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Feb 19, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Blank screen
I had the same problem, so I hit the side of the Garmin a few times. It works perfectly now. Something inside was unaligned and needed a little force to knock it into place. I didn't hit it HARD.
Sep 09, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
83 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
