Question about Uniden Cordless Phone
PHONE WILL NOT RING
THERE IS A "DO NOT DISTURB" ON MY PHONE HAND SETS AND THE RINGER WILL NOT RING DUE TO THIS HOW DO I GET IT OFF SO I CAN HERE MY RINGER
    Problem Solver:
  • 19 Answers
For GE 6.0:  There is a button on the base on the lower right corner (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Posted on Nov 13, 2008
    New Friend:
  • 161 Answers
On the phone i used to own i would have to press and hold the do not disturb button and it would beep telling me that that feature was turned off.....try it and let me know
Posted on Sep 30, 2008
Will not ring on incoming calls
On the top left edge of the iPhone there is a small lever. It is just above the volume up and down controls. Flick it back towards the screen of the phone. This is the 'ringer off' switch. You will get a display on the screen telling you whether you are ringer on, or ringer off.
Other possibility is that the Settings/Do not Disturb setting is activated.
Nov 10, 2015 | Apple iPhone4 4G iPhone 4
Calls go into msg and phone does not ring; volume set. When it's on vibrate only, I get the vibrasion, but when volume turned up, no sound. How can I correct
The phone type makes a difference.
On iPhone check Settings / Do Not Disturb.
Also Ringer Off on left hand side.
Volume has to be adjusted with Home Screen in view.
Oct 01, 2015 | Tracfone Wireless LG 440G
Why is it when people call me my iphone 5 does not ring, how can i make it ring?
check the left side of your iphone and see if the ringer button is down then raise it up and increase the sound volume. Or go to settings then sounds and check the sound level. Else try to restart your iphone if it doesn't work then the problem might be in your iphone speaker.
May 28, 2014 | Apple iPhone 5
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
My uniden powermax 5.8 ghz set itself to Do Not Disturb.
The do not disturb feature (DND) allows you to mute the ringer, the base, and any registered handsets at the same time. The phone must be in standby mode. Press and hold do not disturb on the base. You will hear a confirmation tone, and the DND LED illuminates. To cancel the DND feature, press do not disturb again. You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
Activating the DND while the answering system is off will turn the answering system on automatically. The answering system setting will reset to the original setting when you cancel the DND.
If you press answer on/off when the DND and the answering system is on, both of the DND and the answering system will turn off.
To mute the ringer tone temporarily for each handset or the base, when the phone is ringing, press the MUTE soft key on the handset or the base. The ringer tone will return to the previous setting starting with the next incoming call.
May 28, 2009 | Uniden 5.8GHz Dual Cordless Phone
My ringer will not work.
*79 disables do not disturb mode.
*78 enables it.
type in *79 and press talk. or call 611 and ask for the do no disturb mode number.
Feb 13, 2009 | Palm Treo 700w Smartphone
GE cordless dect 6.0-do not disturb
According to the instructions, you only need to press the "do not disturb" button again. The button is on the base (not the phone).
Mar 04, 2008 | Uniden Cordless Phone
No incoming ring
For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
Hope this helps!
Dec 23, 2007 | GE 28111EE2 Cordless Phone
GE dECT 6.0 Cordless Model 28112 Series
On the base is a button next to the GE logo that says "Do Not Disturb". Pushing that button will enable and disable that feature
Dec 08, 2007 | GE 28112EE2 Cordless Phone
When someone calls the buttons flash but doesn't ring.
Your ringer has been switched off..to solve this press the menu button(mute in most of the sets)and press it until you see the option ringer press + to change it to off and then press menu again until you see the main screen...Thats all..
Let me know if it worked..
Oct 20, 2007 | GE 28111 Cordless Phone
Uniden Cordless Phone Logo
401 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
