Question about Compaq Presario 5000 PC Desktop
Cant get on the internet
The network adapters have yellow astroids by them
  • Exidous
    Exidous May 11, 2010
    It sounds like a driver issue to me. What OS are you running? win98 winME 200 XP or Vista?
  • 749 Answers
Press START-SETTINGS - CONTROLL PANEL- SYSTEM
select the Hardware tab , then select device manager. right click the device with asterick by it and click PROPERTIES, select the "driver" tab at top, then click on "roll back driver". this should change it driver back to the previous (working) driver.
If this a new network card install and NO previous ones before it, you may need to dowmload the correct driver, which will require you to post your network cards info eg: make and model, so they i can help you find the correct one.
Hope this helps
Posted on Oct 07, 2008
TP-LINK TL-WN321G - Hi-Speed USB - 802.11g driver not install in window xp
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"
Apr 03, 2013 | TP-LINK TL-WN321G - Network adapter -...
I got a new computer recently and im trying to switch my adapter from this comp to the other but i lost my CD and i cant get onto the internet to DL the drivers any help?
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers if you cant find the driver hopefully one of these will help you
http://alpha.majorgeeks.com/Intel_Network_Adapter_Driver_for_Windows_7_d6273.html
http://majorgeeks.com/SiS191_Gigabit_LAN_&_SiS190_LAN_Driver_d5923.html
http://majorgeeks.com/IntelR_PROWireless_LAN_2100_Network_Connection_d4598.html Latest
http://majorgeeks.com/downloadget.php?id=5240&file=15&evp=5fbb1c6e47482358c61a5236fb38a112
VIA LAN Driver. If you don
Jun 23, 2011 | Computers & Internet
Cant connect to internet verizon says network
Have you installed tnhe drivers for your Network Adapter? Without the drivers the adapter is, as far as the computer knows, not there. Did you get a disk with your computer and/or adapter? If so install the drivers and problem should be solved.
Dec 20, 2009 | Dell Ethernet Card Network Adapter
Cannot connet ot interner
check the driver of your network controller, go to device manager, to access this, right click my computer then click device manager tab then find network controller then click + sign preceeding of that. if you notice that there is yellow question mark of the network, you need to install driver so that you cant connect to internet
Oct 12, 2009 | Computers & Internet
Did a reformat on my computer now I cannot get reconnected to the internet tells not available offline I am using comcast and running windows exp can you help. I did the reformat from the cd
mak sure you have installed the drivers correctly. to know, you cna go to device manager, by clicking start, click control panel, click system, click hardware, then device manager, do you see any yellow exclamation mark or red X? if one of those say network adapter or ethernet adapter then the driver is not installed. if you cant see any yellow exclamation point or mark. all drivers are installed.
Sep 26, 2009 | Computers & Internet
Internet not connecting
Update the drivers for the network adapters. You may also run recovery cd if you have for those computers.
Sep 09, 2009 | Microsoft Windows XP Professional SP2 for...
Cant access internet without network adapter operating
You can download drivers at
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8400&os=WW1&osl=en&catid=&impid=
If internet is not working , then u might have received a CD with when u first got ur system, it has all the drivers that ur looking for.
If u cant find the CD, then contact Dell Technical support, they will send u one free of cost.
May 24, 2009 | Dell Dimension 8400 PC Desktop
Network adapter
your adapter driver is not installed plz install it
Aug 13, 2008 | Computers & Internet
Trying to hook up internet
Hello
Please check whether the Wireles s button is on and there are any yellow marks in the device manager.
Click start and select Run. In the Run box type devgmgmt.msc and press enter. This will open device manager. Then click on + sign next to network adapters and check whether the wireless adapter listed and any yellow marks beside it.
If there is no yellow marks beside the wireless adapter and it is listed in the device manager. Then try to install Wireless drivers and reconfigure wireless network.
Thanks
Regards.
Jun 21, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 5000 PC Desktop Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
