Question about Dryers
Kenmore 90 series, clothes have marks on them from getting pinched in drum.
  • 943 Answers
Hi. thanks for the question. the back felt is worn. allowing the clothes to slip out. i would replace the back felt, and also clean all the venting from dryer to the outside. save hydro. thanks the appliance doc
Posted on Sep 28, 2008
Kenmore dryer model 110 leaves burn marks
They aren't burn marks, it is the clothing getting pinched between the drum and the bulkhead due to a worn felt seal. Help Me Find My Model Number RepairClinic com
Oct 17, 2016 | Kenmore Dryers
Clothes, fabrics are coming out of dryer with burn marks
If those marks are little brown marks/they do look like burn marks but your cloths are being pinched by the front and rear felts on the drum//to test that take a white rag reach in to dryer at the edge of the drum front and rear rub the rag// you may have to push it between the drum and the dryer housing you will get brown marks that is rust///If you replace front and rear drum glides (seals) that will cure the problem I would price parts first as sometimes replacement is a lot cheaper.......Hope this helped....If I did please vote If you need more help please ask...Good luck
Feb 05, 2011 | Kenmore Dryers
Clothes get tuck on the front edge and discolors
it most probably needs to have the felt cushion on the front of the drum replaced.
Jul 09, 2010 | Kenmore 83042 Electric Dryer
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
I have a Kenmore Elite HE4 gas dryer. It works fine, but leaves small streaky marks (looks like grease?) on some of my clothes - usually silkier, light colored clothing. I have searched the inside of the...
The clothes are getting pinched between the drum and the housing. Check the gasket(s) where the drum turns on the housing at the front and back. If the gasket is worn there is a small gap that clothes can get pulled into. The marks are from the worn metal. Lighter weight clothes are more likely to get caught. The gaskets can be replaced by removing the drum.
Jul 24, 2009 | Dryers
My clothes have brown marks on them that look like burn marks. has this been a problem with maytag neptune dryers? if so, what is going on?
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
Rollers
Rear seal
Front glides
Front seal
Jun 07, 2009 | Dryers
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Dryers Logo
71 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
