Compaq FP 7317  17" LCD Monitor
Problem for Compaq FP 7317 (Silver) 17" LCD Monitor
No sound
By yellowbones on Sep 28, 2008
The speakers on the monitor dont work. And If it was my sound card how do I reapair it
Best Solution
posted on Sep 28, 2008
Very Helpful)
rickzilla
Rank: Guru
Rating: 88%, 449 votes
Hello Yellowbones.. First off.. are you sure your cable is plugged into the appropriate jack on the back of your computer? If it is.. then do you have a spare set of speakers that you can plug into that jack to determine if it is teh speakers or the sound card? If you have a set of other speakers, try that first so we can confirm that it is a problem from your ausio driver versus the speaker set itself.. On the assumption that the sound card is the blame.. You may want to verify that hardware is working properly. You shopuld be able to go into the control panel from the Start menu and find Sounds and Audio Device menu.. once you have that.. make sure you do not have your system set to Mute... and then you can select the hardware tab and find your sound card device in the listing.. once you highlight that, it should tell you if your device is working properly or not.. and give you a troubleshooting tab to walk you thru some diagnostics.. You may also select the driver tab and update the driver for your card to see if that resloves the problem too.
Was this helpful?
Yes
No
Solution #2
posted on Oct 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Don't forget to check the volume control on the monitor
Popular Solutions for Compaq FP 7317 17" LCD
Questions and Unsolved Problems for Compaq FP 7317 17" LCD
Do you recommend Compaq FP 7317 (Silver) 17" LCD Monitor?
Answer
Answer
I disconnected my FP 7317 from a PC and hooked it up to to a new Mac Mini just to boot up. When I... (More)
Answer
can any 1 tell me the IC number of the monitor i repeat the model number again HP7540 HSTND-1A02-M .... (More)
Answer
Hi my supporter the problem with my monitor is when i start to oppen window , it can show that it is... (More)
Answer
I am looking to replace 2 transistors out of my monitor part number are: MP50407 and MP1410EP
Answer
the power button does nothing . but monitor turns on with menu and sound buttons. .before the screen... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Compaq FP 7317 17" LCD...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
