Question about Measuring Tools & Sensors
Clear view screens
How to remove clear view screens.? How to remove the screw that's covered by a cap on both top and bottom ends of the take up side?
SOURCE: VIEWING SCREEN SAYING-PLEASE REMOVE LENS COVER,WHEN THE LENS COVER IS ALREADY OFF..
see web page http://www.jvc.co.uk/knowledge-list.php?id=4#0 Important Notice to Camcorder Customers A. JVC has received reports that in certain circumstances, a small quantity of units of the models listed below, may, while in the camera mode, show no picture, a distorted picture and/or display "LENS CAP" even though the lens cap is removed. We have identified the cause as a failure of the CCD image sensor. Until 1st October 2007, JVC will cover the cost of repairs of units exhibiting these symptoms. If your product is within the twelve month manufacturer's warranty, please return it to your retailer who will arrange a repair under the terms and conditions of the warranty. If your product is outside warranty, please write to: JVC Consumer Support JVC UK Ltd 14 Priestley Way London NW2 7BA Please enclose a copy of your purchase receipt and warranty certificate. Please note that proof of purchase is required. PLEASE DO NOT SEND YOUR CAMERA DIRECTLY TO JVC. You should send ONLY your purchase receipt and warranty certificate with a covering letter. JVC will contact you to advise how the repair will be carried out. Please call 0870-330-5000 if you need any assistance in obtaining a free repair. We apologise for any inconvenience and are appreciative of your understanding and support. Model Numbers Affected VHS-C Camcorders GR-FX15E, GR-FXM393E, GR-FXM39E, GR-FX16E, GR-FXM404E, GR-FXM40E, GR-SX19E, GR-SX25E, GR-SXM29E, GR-SXM49E, GR-SX26E, GR-SXM30E, GR-SXM50E DVC Camcorders GR-D20E, GR-D21E, GR-D22E, GR-D30E, GR-D31E, GR-D40E, GR-D50E, GR-D60E, GR-D70E, GR-DX25E, GR-DX35E, GR-DX45E, GR-DX55E, GR-DX75E, GR-DX95E, GR-PD1E, JY-HD10E, GR-D18E, GR-D225E, GR-D23E, GR-D24E, GR-D32E, GR-D33E, GR-D34E, GR-D43E, GR-D53E, GR-D54E, GR-D63E, GR-D73E, GR-DX27E, GR-DX28E, GR-DX36E, GR-DX37E, GR-DX47E, GR-DX48E, GR-DX57E, GR-DX67E, GR-DX77E, GR-DX78E, GR-DX97E
Posted on Jul 31, 2007
SOURCE: Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Posted on Mar 26, 2008
mdavinci
  • 20 Answers
SOURCE: CMOS Battery dead, No Post, No System Beeps
bloody hell! All the ones I have used (IBM, Compaq and Dell) have clear access to the battery!
That sounds very frustrating!
My Solution, drop kick it out the window if you have to replace another!
Posted on Mar 18, 2009
SOURCE: Eureka model 4335 - belt removal (top cover)
loosen two screws on either side on top of the housing lifts off the top. exposing the roller and the broken belt.
Posted on Mar 25, 2009
SOURCE: replacing side view mirror cover on 200 SAAB 9-5
I need a complete passenger Side Mirror (2nd Hand) N-95 (S Reg) contact 07966 366195
Posted on Jul 21, 2009
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
Replace lcd on gateway NV57h77u
I disagree. The procedure is so easy no Service Manual is needed
1) Remove ALL power. Remove the AC adapter, and Battery.
2) Open the laptop.
The plastic frame in front of the LCD screen is the Display Bezel.
(Gateway? Believe they call it the LCD Panel Bezel)
Down in the BOTTOM corners, next to the Hinges, are screws to be removed. One in each bottom corner.
There are Screw Covers over these screws. The Screw Covers need to be removed.
Little round covers I believe to be made of plastic.
(Some models they are made of synthetic rubber)
I use a computer pick to Gently remove them.
Some use the tip of an X-Acto knife. I do not recommend this as there is a possibility of injury.
Perhaps a large darning needle. (Needle you sew with, but is Large in size)
Pick up at one edge of Screw Cover. Screw Covers are held on by a type of rubber cement.
I LIGHTLY stick them to the Display Bezel for safekeeping.
(Yes. They like to stick to the tool, your fingers, and it seems passing jets in the sky.
If you are careful with them, you should be able to reuse them.
If they do not stick anymore, use a toothpick, and apply a TINY dab of rubber cement to them/it )
Once the Screw Covers are removed use a No.1 Philips screwdriver, or equivalent Jewelers screwdriver; to remove the 2 screws.
The Display Bezel has TABS going around the exterior perimeter, of it's inside edges.
These Tabs snap into matching LATCHES on the Display Cover.
You can come from the Outside edge, where the Display Bezel meets the Display Cover, and use a thick guitar pick.
The guitar pick is wedged into the parting line, of where the Display Bezel meets the Display Cover.
Once a 'crack' is formed in-between the two, then the fingertips are used to gently start popping the bezel from the cover.
You slowly go along with your fingertips, and work along the top, then sides. By the time you have both sides almost loose, the Display Bezel usually pops off.
I like the flex method.
Come to the inside edge of the Display Bezel.
Where it meets the LCD screen. I suggest start on the Right side/Middle.
Use a fingertip, and lift up the inside edge of the Display Bezel up a little. Can't lift up at that spot? Move over. You are at a Tab/Latch.
With this spot lifted up a little, use the fingertip of the other hand, and slide under next to it.
Now use your fingertips as wedges, and pop the Display Bezel loose a little at a time.
I start at the Right side/Middle as stated. Left hand fingertips go DOWN the right side, Right hand fingertips go UP the right side.
Then I go across the Top, and down the Left side.
MOST of the time, as stated; the Display Bezel usually pops off when right side, and left side are most of the way popped loose.
NOT always though!
Sometimes you have to pop EACH and EVERY Tab/Latch loose.
Also; watch around the Hinge area/s.
Display Bezel can get hung up around them.
Go slow, and gently work the Display Bezel off, around the Hinge areas.
Display Bezel popped off, sit back; relax. You just did the hard part.
Wasn't so tough, huh?
This is what the Display Bezel looks like removed,
http://www.ebay.com/itm/Gateway-NV57H15U-LCD-Front-Bezel-15-6-AP0HJ00021-/171020787909?pt=LH_DefaultDomain_0&hash=item27d1a220c5
The MAIN view shown is a BACK view.
In the smaller views underneath, the 4th view from the Left, shows the FRONT view.
If you SET your mouse cursor in the middle of the Main view photo, the Zoom In feature is enabled.
You can CLICK on any of the smaller views, to make them appear as a Main view.
You can also see that the Hinge Covers, are an integral part of the Display Bezel. Shows you that when removing the Display Bezel, these Hinge Covers may need to be worked off of the Hinges.
Of course, may not; as I have previously stated.
The LCD screen is an Assembly. It is composed of layers.
These layers are kept in the factory set alignment, by a metal Screen Frame.
The Screen Frame resembles a picture frame.
There are THREE screws on each side of the Screen Frame.
These screws (Philips) go through metal Brackets, and hold the LCD screen/Screen Frame; to the Display Cover.
The Brackets are an integral part of the Hinges,
http://www.ebay.com/itm/Gateway-NV55-NV57-LCD-Left-Hinge-Rail-Bracket-AM0HJ000100-/400334888754?pt=LH_DefaultDomain_0&hash=item5d35d19f32
On EACH side, there is 1 screw towards the Top, 1 screw towards the Bottom/Middle, and 1 screw towards the Bottom.
Remove all 6 screws.
At the Top is the Webcam Cable. Unplug it from the Webcam Module.
(Cable pulls to LEFT side, facing laptop)
The TOP of the LCD screen is now tilted forward.
The Video Cable plugs into the Bottom side.
There should be a piece of clear Mylar tape, holding the Video Cable connector in place. Carefully peel it back, unplug the Video Cable from the LCD screen.
Remove the LCD screen.
Reverse steps to install new LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
A) http://www.insidemylaptop.com/replacing-lcd-screen-on-gateway-nv57h13u-laptop/
B) http://www.youtube.com/watch?v=ENmPg46IB9Q
Apr 12, 2013 | Gateway Nv57h77u Laptop/notebook
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
Need kenmore electric dryer model 110.66662500 wiring diagram. will not heat
Should find the wiring diagram under or in behind the control panel accessed by removing the 2 screws holding the panel down either in the front lower or rear lower end caps . If you can't see any screw heads there may be removable covers on the end caps from top to bottom . On some newer models you can insert a putty knife under the end caps on the front and depress a clip on either side and the whole control panel lifts and lays back. Before any of that check your fuses at the panel 2-- 30 amp
Nov 04, 2010 | Kenmore Dryers
Rca tv is blurry
2 types. If wooden top rail of screen surround: remove end screws of top rail by removing caps over screws on upper front sides. Remove the two screws. Remove top wooden screen bezel piece. Now pull up and out screens. If sceen surround is plastic one-piece all-around: remove speaker grill board. Remove screws along lower front of screen bezel. Pull bottom of screen bezel out a 1/2 inch. Lift up on screen bezel to remove entire screen assembly.
May 06, 2010 | RCA P52926 52" Rear Projection Television
It wont print and everytime i try to print it says error #1200
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable2_bing.gif to reveal the gold screw beneath
7. Remove the ink cartridges2_bing.gif out of their carriage.
Figure 6 - Displays ink cartridge2_bing.gif carriage with ink cartridges removed.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
9. Lift the front cover open (if not already open) and plug in2_bing.gif the X4270. Cartridges should move to center as if preparing for replacement.
Click Here for the Documents
May 03, 2010 | Lexmark X4270 All-In-One InkJet Printer
The lights which tell you if you are going at the right speed on my Bissell PROHeat Pro-Tech have stopped working. Just wondering if this could be as simple as a bulb or more serious. Also, how do you...
I have this same model and never noticed the lights telling me the "correct speed" learn something new everyday....
the clear plastic hood removes with a few screws connected to the base at the bottom. the top part snaps out. :)
Mar 26, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I get a 1200 error when trying to fax
5. Remove the screws underneath the front cover (6 screws), back ofprinter (2 screws), and bottom of printer (1). View the images below tofind where to remove the screws.
5. Cont…
NOTICE: The ink cartridges are all the way to one end. If the X4270 isplugged in, the cartridge carrier is stuck and doesn’t move. Afterfurther investigation a noticeable small black plastic lever ispreventing the ink cartridges from moving. Photo below shows lever upand down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200.Image on left displays lever up. Image on right displays lever down.
9. Lift the front cover open (if not already open) and plug in theX4270. Cartridges should move to center as if preparing for replacement.
Note: The cause of this problem is the spring slides out of place overtime, probably because of ink shed on one end of its loop and loopattachment.
12. Place spring in loop attachment and use hot tip of heated toolto melt top of loop attachment to prevent further errors. Melt top ofloop attachment similar of that to a mushroom top.
Feb 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
Bissell Proheat Carpet Cleaner
First remove the some cover on the lfet side that is on top, then turn unit over, remove the red lock plate, has 1 screw, pull it out, then you can pull the end cap out, remove it, the cogged belt is there. If while you have the brush roll off, the pump belt can be replaced also. REmove old belt, put new belt over the bigger round part of the pump pully, feed it thru opening, then from the top, grap it and stretch it over the motor shaft. Then put the cogged belt on and reinstall the brush roll and the red lock.
Jan 31, 2008 | Bissell 1699 ProHeat Clear View Upright...
Scanner failure error
Take the top off and clean the underside of glass as well as the mirrors on the scanner. Remove the bulbs. This is a light job but not for the mechanically impaired. If you have a 7110, take the ADF off by lifting 2 black inserts near the hinges. Remove 3 screws - 2 near ADF hinges and one on the right.
- Pop off the button cover.
- Remove button assy by sliding right, lift up and pull forward. Remove cable and 2 screws in view.
- Pop off the front plastic piece that the button assy. rested on.
- Remove 1 or 2 screws on the underside center of the top glass assy.
- Open printer exposing the print area and remove the front hinges on the bottom by moving the tabs on left and right side of both hinges.
- Remove a few screws holding the top cover in place.
Cleaning the mirrors.
- Remove the top plastic cover on scanning assy by inserting a small flat blade on the left and right (just behing the lights) and release tabs. Lift front upward till rear tabs are free.
- Remove the bulb toward the middle of the scanner assy. by unplugging, unsnake wire and lift up only that end enough to clearing so you can slide the other end out.
- Remove screw holding dont the clear plasic guide.
- Unplug the other light and unsnake wire. Lift that end up only until the clear plastic piece clears guides and then slide both plastic and light until the other end of the light is free.
Clean mirrors carefully and wipe bulbs carefully
Then Reassemble.
Jan 27, 2008 | HP OfficeJet d145 InkJet Printer
Measuring Tools & Sensors Logo
48 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
