Question about GE GSS25SGMBS Side by Side Refrigerator
Trouble Shooting Warm Fridge
Fridge was warm 2 weeks ago. Checked on here and diagnosed bad defrost heater. Replaced it and everything good for two weeks now warm again. When I removed the back panel coild all frozen again. My fride has no defrost timer so I followed instruction on site and jumpered the Line and defrost terminals. My heater came on though, so now it dosent seem to be the motherboard or the heater. What else could it be..????
I had this same problem. unfrreeze the heater. Splap it together and turn the freezer temperature up to 5 degrees. It will work fine thereafter.
Posted on Oct 15, 2008
  • 943 Answers
Hi thanks for the question .in the freezer a small disc with 2 wires going to it that's the defrost termination switch if a fail will not let the to come on . replace it thanks the appliance doc
Posted on Sep 28, 2008
Good morning - my Kenmore refrigerator is 1 year and 2 months old; I did not purchase a $250/2 year warranty. Now I wish I did...my refrigerator is warm; no cold air blowing inside. The freezer is working...
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
The compressor and sealed system will have a five year warranty.
Feb 13, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
I replaced the defrost thermostate a couple of weeks ago & its still freezing up & not cool the fridge side. Any suggestions?
DEFROST PROBLEM
Feb 02, 2011 | Frigidaire Refrigerators
Fridge freezer installed 3 weeks ago and the top half of fridge back freezes. Dial is on 1 dot.
DEFROST PROBLEM
Nov 02, 2010 | Tecnik TKR6610 Bottom Freezer Refrigerator
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
Fridge not getting cold. Replaced evaporator 1 year ago. all good. 2 weeks ago stopped getting cold again. called approved tech. checked everything and said thermostat was bad. being an electrician, i...
You have a leak in the refrigeration system somewhere...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 16, 2010 | Refrigerators
Condenser not defrosting. I have a F44R21NGW1. The condenser coils won't defrost. The appliance repair service has already replaced the defrost timer and declared everything else working. It worked fine...
DEFROST PROBLEM
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
Part 23 on this diagram is your defrost timer.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=108655&diagram_id=252596#d252596
Jun 13, 2010 | Refrigerators
Have a GE GSS22KGMA side by side. Fridge gets warm at the top
Hi and welcome to FixYa. I am Kelly
I am going to paste part of your text and then reply:
Your text:
Repairman came back and replaced a small round part at the top of the evaporator (resistor??) <
{ That was the termostat}
I just read that the problem could be the defrost thermostat..
He already replaced it.
I hate to say it but is sounds like your in repairman hades.
So far I see 1. a new mother board, 2. new defrost thermostat and 3. new defrost heater element. (other than wiring that is everything in the circuit)
Either one of the 3 NEW parts is bad or...there is a partially broken wire in the circuit.
Hopefully this helps you understand. ( I know it does not fix your uint)
Thanks for using FixYa.
Kelly
P.s your words again:
one would expect this to be remedied.
You got that right!
Feb 11, 2010 | Refrigerators
My freezer frosts over, then the fridge is warm. If I defrost the freezer, the fridge works for 2 weeks again
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Oct 25, 2009 | Refrigerators
Hotpoint side by side 2 yrs old. I have to manually defrost every week. Had 2 computer panels and 1 defrost heater replaced.
I would start from scratch and diagnose the problem.
Oct 10, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Mar 18, 2009 | Maytag MBB1956GES Bottom Freezer...
GE GSS25SGMBS Side by Side Refrigerator Logo
110 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
