Question about Microwave Ovens
A little metal is showing at the inside roof of the microwave.
When i turned the microwave on there was sparks , as i looked inside a little metal is showing at the roof of the inside of the microwave can it be repaired ..........thats's the only thing that is wrong .
  • 99 Answers
Rub down with fine wet & dry ,paint with Humbrol enamel to match.
Posted on Oct 13, 2008
I need a microwave wave guild cover
Connie, look inside to see if something metallic is in the oven, like aluminum foil. Sparks should not be present. Also remove the grate/shelf if there is one and check under the turntable for metallic pieces. Actually take the turntable out. Test using a glass of water. 1/2 min on high, water should get warm
Apr 23, 2014 | Daewoo KOR-1B4H Microwave Oven
Microwave sparks
If it sparks inside the oven then look inside for any powder paint missing... if so discard. If you has metal shelves or tin foil then don't put metal in when on microwave setting. Some of these metal shelves are for a microwave that is also a convection oven but only in the convection oven setting.
Nov 26, 2013 | Thermador Microwave Ovens
Kitchen aid microwave Kcms185j is arcing on the inside ceiling when popping popcorn, but normal when frying bacon?
It may be the oil in the popcorn---do you own one of the covers that go inside to cover so food does not splatter?
Dec 22, 2012 | KitchenAid KCMS185J Microwave Oven
Microwave sparks
Look in side and make sure there is no pieces of aluminum foil or metal hidden inside. If not I would not use until you have a appliance repair person look at it.
Apr 07, 2012 | Dacor DMT2420 1200 Watts Microwave Oven
My Goldstar MV-1310W microwave has sparks flying from the metal plate that's inside on the top.
Microwave ovens do not work well with exposed metal. IF you place uncoated metal in the oven, sparks will occur.
IF the interior of the oven has the metal exposed, it will cause sparking to occur.
There must be NO exposed metal inside a Microwave oven!
Aug 15, 2011 | Goldstar MV-1310W/B Microwave Oven
Turned it on to heat food and make a loud noise , did not heat food and have electrical short ordor.
there is something metal inside that is causing this look for any screws or anything that may have been switch with a repair. what happens is the metal causes the microwaves to reflect back to the magnetron instead inside the food causing noises and sometimes sparks and odor. find the metal object remove it and this should solve your problem
Jan 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Sparks when micro turned on. it appears the pannel
Yes if you can find someone to supply it as a spare part. Clean any grease or debris from behind it too. Often there are little plastic rivets that hold it on. You might as well order them too. If it burnt too bad there will be a carbonisation on the panel too which must be cleaned off as it will attract the microwave energy.
Before ordering anything, remove the burnt panel and run the microwave with just a cup of water in it to make sure it still works fine.
Whatever you do, do not open up a microwave oven cabinet, they are very dangerous inside. If you cant remove the panel from within the cooking cavity then leave well alone and get an engineer to look at it.
Aug 04, 2010 | Dacor DMO24SS Microwave Oven
I'm getting a flash inside the oven and the plastic on the inside roof has a burn mark. I removed the plastic cover over the micro wave generator and it did not spark. is the oven dying? It is a 1983 0ver...
It looks like the metal part inside the oven is exposed to the high frequency rf waves. this may sound strange but try coating the metal part with fresh paint. remember no metal inside the oven will stand the waves created inside the oven the spark u see is the waves hitting the exposed metal part inside the oven
Oct 13, 2009 | Magic Chef MCD1311ST Microwave Oven
Sparking roof of my miele M613G microwave
these ovens are favourite for this, it is something to do with the stirrer blades. the top casing can be removed and replaced
Feb 23, 2009 | Miele M613GSS 800 Watts Convection /...
Microwave ovens
The cover is probably the magenetron. That is where the microwaves come from. If the bread was moist, it might have left condensate in the unit which is causing the sparking. Unplug the unit, leave the door open over night. If you can remove that cover, do so. Be sure to carefully replace it before using the unit. Never turn on a microwave with nothing in it.
Dec 16, 2007 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
220 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
