Question about Bazooka (EL10190PP) Car Audio Amplifier
No idea!! OK, so... I have checked every wire, every ground, remote turn on. everything. i have power to the amp but it wont turn on. Bazooka ELA1300. I have checked fuses and checked all connections. I have no idea... help?:(
  • 631 Answers
Have you checked the on-board fuses on the amp?
Have you confirmed, with a multimeter, that you have B+ and remote voltage AND a good ground? If not, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Sep 29, 2008
How to i find out whats wrong with my bazooka tube i tried to hook it up to a car battery and car stereo out side but wont work ???
follow this steps and fix it. GOd bless you
  • Verify that the amplifier is turning on by looking to see that it is lit up.
  • 2
    Use a voltmeter to verify your power supply is a good 12 volts by touching the ground lead to you amplifier's ground screw and the positive one to the amplifier's constant power supply screw. Also verify that you have 12 volts coming from the remote lead wire which is usually a thin blue wire between the ground and constant 12 volt supply.
  • 3
    Look for the "thermal overload" light. It is usually a red LED on the side of the amp. If the amp feels really warm and this light is lit, the amp has probably overheated from being tuned wrong or turned up too loud and shut itself down to cool off.
  • 4
    Check the fuses on the amplifier. These can blow with extended use or during heavy bursts of use.
  • 5
    Make sure the "Gain" and other volume controls are turned up.
  • 6
    Confirm that the signal wire is still attached to the amplifier and has not come disconnected by vibrations in the car. Also check that the wires running out of the amp to the speakers are still attached to the amp.
Oct 27, 2013 | Car Audio & Video
I have a EL 1500wat amp, when I turn it on the little lite comes on and stays yellow, it was green and was working,fine last night. Any ideas?
Look at fuses first. Then if they are ok. You need to check wiring. Ground. Power remote. If those are good. You need a tech.
Apr 16, 2012 | Bazooka EL1500 Car Audio Amplifier
My protection mode red light comes on right when i put the fuse in my power line, even when my cars off!!! is it that my ground is bad? ineed some help!! oh ya, lol, its a ela300.1 bazooka amp!
Check your ground most definitly!, Replace it if needed. Check your remote wire and power wire as well. And if none of this works, then you are having internal issues.
Aug 26, 2009 | Bazooka ELA300.1 Car Audio Amplifier
Amp wont turn on
have you checked the remote wire is supply power? try jumping the main power wire t the remote wire to see if it turn on. Also check that your ground wire is securely making contact.
Apr 20, 2009 | Kenwood KAC-8152D Car Audio Amplifier
Bazooka BTA series self-amplified tube subwoofer wont' power on
the blue wire is called the remote wire will go to back of head unit also to a bule wire that will send 2 amps to turn on the speaker only when the head unite is on
Apr 18, 2009 | Infinity BASSLINK Car Subwoofer
Got the hot nd ground conted nd the aux cables from the raido conted nd the amp does not turn on
The amp needs a remote signal to turn on. This is provided by wire from the back of your head unit. Also look for a 'REM' or 'remote' connection on the amp (besides the 12v and ground connection).
Look at the wiring/setup diagram for your head unit to determine which wire/connection you should use for this.
If the head unit does not have a specific 'remote' wire, you can usually use the power antenna wire to provide a turn on signal to the amp instead.
Apr 13, 2009 | Bazooka EL1500 Car Audio Amplifier
Bazooka amp
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it remains in protect mode, the amp almost certainly has shorted output transistors and will need to be repaired.
Jun 15, 2008 | Bazooka Car Audio & Video
Whats wrong??
you should check the remote wire bc you will get power to your amps if its not hooked up but you wont get any music!
Aug 22, 2007 | Bazooka ELA300.1 Car Audio Amplifier
Amp not turning on
wouldn't be the first JL amp I saw fried...but there are some tests you can do. First of all, double check your fuses, they may appear to be fine, but sometimes they are blown even if you can't see it. Either blindly change them or test them for continuity with a digital multimeter. Also, disconnect the remote turnon and jump power directly over from the power wire to the remote terminal on the amp, if the amp powers on then you have to go double check your remote wire. Hope this helps.
Jul 27, 2007 | Kenwood Excelon KAC-X811D Car Audio...
Bazooka (EL10190PP) Car Audio Amplifier Logo
97 people viewed this question
Top Bazooka Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
rd2xpld
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
