Question about Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio
Yaesu FT 11R
I cannot program or punch in above or below frequencies 144.000 to 148.000 mhz on this radio. I have done factory reset, and mod reset, but still doesn't work. Any suggestions?
  • stevepaint Jan 08, 2009
    I cannot program any frequencies above 148.00 or below 144.00 on my ft-11r. I left the radio on all night on a local police frequency of 154.415 and in the morning it was reset to the above condition, with the battery almost discharged. How can I get it back to receive frequencies above & below the 2m band?
Figured out how to solve this, with the radio off, push and hold both up and down scan buttons, while powering the radio on. This will fix the problem.
Posted on Jan 10, 2009
  • 55 Answers
That specific radio is a Single Band radio for 2m only.
Here is a website to modify that radio for extended band coverage.
http://www.kb2ljj.com/data/yaesu/ft-11r.htm
Posted on Nov 09, 2008
How ti unlock transceiver radio Yaesu FT 1900R to transmit beetwen 136 to 174 Mhz
Here is a link to a forum that has instructions for how to make the modification: http://www.worldwidedx.com/threads/expanded-tx-mod-for-ft-1900r.37171/
Aug 19, 2014 | Yaesu Ft 1900r Vhf Mobile 55 W Two Way...
Ft 2900r yaesu all i see on the screen is B0001 i can't see the frequency
Try powering the unit up while holding the Set/MHz button. I did that and it restored the display (and the rest of the radio's operation) back to normal.
The character codes are test-mode displays that correspond to frequencies (in MHz):
A0001-A0640 - 136.000-143.9875 in 12.5 KHz steps B0001-B0400 - 144.000-147.990 in 10.0 KHz steps
C0001-C2081 - 148.000-174.000 in 12.5 KHz steps
I haven't the foggiest idea why this isn't in the manual somewhere, or at least flipped back to normal by a two-key or three-key reset. 73, k2mct
Sep 16, 2012 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Will only work in the 144.000 - 146.000 range
That is the spec range for this radio. You may be able to find instructions to operate "out of band" on "www.mods.dk".
Aug 12, 2011 | Vertex FNB-35M,...
I want a manual for a yaesu vx-5
You can probably find it on www.mods.dk - you may pay a small fee, but they have manuals for most ham radios.
Sep 27, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu FT-11R amateur radio squelch problem
It sounds like perhaps you have CTCSS turned on so it's blocking received signals that aren't using sub-audible tones. Make sure the "TSQ" indicator is not showing. Most Yaesu radios have the SQU or "T.SQ" option easily found in their menu structure..
Nov 12, 2009 | Vertex FNB-38, YAESU,FT-11R,FT-41R,FT-51R,...
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
Service manual/parts list for yaesu ft41r or ft11r
You should be able to get the keypad from Yaesu parts: \
(714)827-7600
You may be able to download the manuals at: www.mods.dk
Sep 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
After factory reset of yaesu vx-5 can not get out of nfm
Check the frequency step setting. If you have it set to 12.5kHz it's possible that's forcing the nfm mode.
Dec 26, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu
Here is a good website with radio mods for most radios, here's the mod for the vx2, also note the other files, I guess that radio has had a few problems in the past....
http://www.ham.dmz.ro/yaesu/vx-2r-freeband-mod.php
Oct 29, 2008 | Radio Communications
Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio Logo
1,157 people viewed this question
Top Vertex Radio Communications Experts
Steve
scott265
Level 1 Expert
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
