Question about Maytag MAH8700A Front Load Washer
Maytag neptune mah8700aww wont drain, spin or put water in
What-where and how do I check for water blockages into and out of the washer? Error code is nd. Nothing is happening and I don't want to burn out the motor if the water is clogged somewhere.
RB
  • 2 more comments
  • jodiekane99 Nov 06, 2008
    My washer got stuck and had the nd code too, but now my door is locked and won't unlock. I have unplugged it for almost 20 mins, then plugged it back in to see if it would reset and it won't. I need to get into it right now, my kids school clothes are in it. SOMEONE PLEASE HELP ME!!!
    Okay so I finally got the door unlocked. I tried to drain my washer manually and water went all over the floor. It smelled really bad, and I just put the load in today around 4, so I think its been holding water. Now it won't spin or drain at all. Are there any suggestions so I don't have to call someone, or is it hopeless?
  • molejnik May 11, 2010
    My washer has done the same. Manually drain washer (grey hose and a bucket) then run on 9 minute SPIN cycle. Doors will unlock at the end.
  • Anonymous Mar 26, 2014
    flashing nd wont unlock door
  • 32 Answers
If you remove the oval cover in the back of the mach,you will find the pump.there are 2 hose clamps to remove.usually you will find change stuck in the pump.remove the screws on the bracket that holds down the pump and you can take the entire pump out...good luck
Posted on Sep 29, 2008
  • joshburley1 Aug 31, 2011
    I have a ND code, I took apart the pump and it was pretty clean. I put everything back together and ran it again, I still get a ND error. Could my pump have gone bad? How would I know without purchasing a new part?
Screwturner, I had the exact same problem took the pump completely apart and found a nickel caught inside the drainback flap inside the pump. after having to wash clothes at the laundromat for a week I'm so thankful to find your solution worked. You're the best
Posted on Nov 30, 2008
  • 3 Answers
Thanks a lot, this post helped me to remove the quarter stuck inside the pump by taking apart, I wish they should have a way to stop this problem!
Posted on Jul 02, 2013
  • Anonymous Jun 14, 2015
    There is a way. Make sure you check all pockets before laundering clothing.
OMGOSH!!! THANK YOU!!! These postings really helped us out and saved us a lot of money. A week ago our Maytag Neptune washer stopped in the middle of washing a load of clothes. The water would not drain. Clothes stuck inside and code that said ND and the door would not unlock. After reading the manual and trying to trouble shoot on our own. We came across your posting's here on this site.. My husband did as you all said. Took the pump out and took it apart and found the problem. A quarter was stuck in there and blocking it so the water could not drain properly. He put it all back together. The door now unlocked and we did a practice wash with no clothes. We did add 1/4 vinger to get rid of the smell from the wet clothes being stuck inside for a few days. I am HAPPY to say our washer is working perfectly... I wanted to post our story in hopes this would help someone else.
Posted on Mar 10, 2013
What does error 3 mean
Posted on Dec 08, 2009
I had the same problem and after reading screwturners post i checked it out and it was a little tiny match stick stuck in there thanks so much
Posted on Feb 20, 2009
My washer when it is off still pours water into the machine
Posted on Oct 09, 2008
My Maytag Neptune MAH8700AWW washer when in the spin dry mode shuts down with a suds error?
Check your drain hose for kinks or blockages, check filter and pump for blockages, check wire harness connections to pump, pressure switch and CCU.
I machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Dec 29, 2012 | Maytag Washing Machines
Maytag neptune MAH8700AWW washer will not complete the spin cycle. It spins both directions but never goes past 6 minutes on the display. Eventually you get the "DC" error. It does this with or without...
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(&^%
Sep 15, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune Washer MAH8700AWW will not spin. It will fill, drain, tumble ect but will not spin. i tried a quick spin test and it sounds like it is trying to drain after all the water drains. I went...
You may have tried this, but check the door switch, and the pressure switch(water level switch) to see if either could be bad. both of those affect whether the washer spins or not.
Jun 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Removed both water pump hoses, No blockages drum still has water init. Is this normal? Won't drain and go to final spin. Pump clean and spins free. Maytag Neptune MAH5500B
Water pressure switch adjustment or clogged. Check the small connecting hose to the switch body.
Final spin command signal generates from this part only.
Mar 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
Feb 25, 2010 | Maytag MAH9700AWM Neptune Front Load...
I keep getting the error code nd on my Maytag neptune whats this mean?
Error ND means that there is a drain problem.
Either there is debris inside drain pump hose, or the pump itself is faulty.
The problem is fixed accessing the drain pump hose to check for a blockage.
Keep a container ready to collect water when you undo pump hose.
Parts and diagrams available here.
Nov 14, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH8700A Front Load Washer Logo
2,934 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
