Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Cleaning solution just flows out
It seems that the cleanig solution just le3aks oput all over Any thoughts?
  • 4 Answers
Make sure the cap and the inner valve is seated tightly. There should be a black rubber gasket to help seal the cap and valve. A quick test is to fill the cleaning soultion tank with water (so not to waste the cleaning solution) turn it over and see if it leaks. If not then the problem would be where the tank sits in the unit. Make sure there is no debris in the unit where the tank sits.
good luck
D...
Posted on Oct 06, 2008
Hoover working but nothing is going into the cylinder
Check there isnt a blockage in the cleanig hose, if you have a marble you can run the through the hose when it is disconnected from the Vacuum and if it fails to appear the your hase has somre sortof blockage which neds to be cleared.
Dec 13, 2016 | Hoover Vacuums
My brew station leaks water all over the counter top before it is brewed.
Mine Too! So frustrating. I have to take out the coffee filter, then remove the piece that it sets in. Make sure and clean the spring and the hole in the bottom. This seems to cure the problem until the next time. It seems to get plugged up quickly. I have learned to rinse it out every time I make coffee.
Feb 12, 2015 | Hamilton Beach Brew Station 12 Cup 48465
Flow indicator not spining
Yes I also had this problem after just one use. There's several things that you should check. 1. pull side panel off where the belt is located and see if the liquid in the clear tubbing is flowing.I there is a bubble in the line the pump has lost it's prime and needs to be turned off for a minute then restarted. 2. make sure the belt is not broken this drives the solution pump and well as the cleaning wheel. 3. the lines that the solution flow though are clogged. always rinse the machine with water when done cleaning. Good luck.
May 31, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Bissell Pro Tech Pro Steam Cleaner - no suction @ pump
Take a look at the Service Center Repair Manual (courtesy of Bissell New Zealand):
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
There's a (basic) diagnostic routine for cleaning solution flow (page 7). However, there's a step that's (somewhat) left out. If you follow the diagnostic and get no spray, then try to spray with the hand-held upholstery thing. If:
1) you can spray cleaning solution with the hand-held upholstery thingie, and
2) there's no pinching of the lines at the base of the unit,
...then your heater block is probably blocked. There's a Lower Handle Disassembly guide (page 20) which you can follow to get at the heater block. The input port on mine was blocked with lime, and quite clearly so (I live in an area with pretty heavy water). You can also take the heating block apart (page 8) to better clean out the flow channels, and apply some descaler. I suppose you could also just recirculate descaler through the input and output ports of the heater block, but I wasn't exactly equipped to do so.
If you can't spray cleaning solution from either the upholstery thingie or the main unit, you probably need a new pump. Word of advice: get the one with the METAL PULLEY on the end. The old ones had plastic pulleys which often failed or deformed to uselessness after a while. Since the pulley wasn't replaceable, you had to order the whole pump assembly. Bissell maintains a list of service centers in various countries / cities which can either repair your unit for you, or, considering the name of this website, sell you the parts.
Oct 07, 2008 | Vacuums
Bissell Momentum 12amp
did you change both filters. Mine had the same problem. After changing both filters, (one under canister and one on side of vaccum) the problem left.
Aug 02, 2008 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
98 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
