Question about Refrigerators
We have a Sears Kenmore Elite side by side fridge with water/icemaker on the door. What is the best way to clean all the surfaces that get all moldy? Too many nooks and crannys to get at without somehow taking some of those parts off. Currently we just spray a mild bleach solution all over the parts, clean off what we can, and then let the solution evaporate overnight. OK, but does not get at everything. Any advice? Thx
  • 943 Answers
Hi thanks for the question i know its hard to get at some of those places maybe a baby bottle brush and some vinegar try that thanks the appliance doc
Posted on Sep 28, 2008
Fan noise coming from inside a kenmore elite refrigerator..
Sounds like the fan gas come loose on the shaft and slid into its cage.
Dec 15, 2013 | GALAXY Microsystems 25.4 cu. ft....
Kenmore side by side ice maker sprays water into freezer
Is it actually spraying out of the icemaker or is it running down the back of the freezer?
Jan 31, 2013 | Kenmore Elite Sears & Other Brands...
Icemaker wont work,what to do?
Try pulling the fridge out from the wall and making sure the intake hose from the water line isn't clogged, as can happen with hard water. A pipe-cleaner from the craft section at Walmart can be used to clean it out if it is.
Aug 31, 2012 | Kenmore Side by Side Refrigerator
My Kenmore Elite Model #795.71053.010 3 door bottom freezer makes ice, but will not harvest. I can get water out of the door. Icemaker part # AEQ72910401. I have unplugged frigerator for 30 minutes. I...
I am sorry there is no replacement parts for this icemaker. You will need to replace Icemaker. Call sears if less that 1yr old. I have seen this icemaker go after only 14 months. I hope this helps
Aug 25, 2011 | Refrigerators
Ice maker issues - what to do next?
I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore elite fridg that is not making ice,but i have water at the door. modle # 50509990. THANKS.
Pour about 2/3 cup of water into icemaker ( if there is no cubes in there now ) . If the icemaker dumps the cubes when frozen , replace the water valve . If it doesn't dump , replace the icemaker . Also make sure the coils at the bottom of refrig in front , are clean of dust , lint , pet hair , etc . Also check the plastic hose inside the freezer , to the icemaker , to make sure it is not frozen . If it is , replace the water valve , due to slow drip leak .
Sep 05, 2009 | Kenmore Refrigerators
Ice maker not making ice
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Jan 04, 2009 | Kenmore 53642 / 53644 Side by Side...
Icemaker Kenmore
You either have low water pressure to the fridge or fridge water valve is not completely closing causing water to constantly drip through fill tube, Do you have a side by side? if so does water come out steady through the door?
Nov 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker not working
mike you might have a frozen fill tube check for that also are you getting wtr ook at the dispencer if you dont recheck water supply again
Oct 13, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
