Question about Kenwood Car Audio & Video
Car sound system
I currently have two Kenwood KAC-8103D amps and two Apline type R's and I trying to wire them up so the one amp powers one Sub but i dont know how i should have the imput set up. I had one side(red input wire) going into one amp and the other side(black/white input wire)into the other. When its on the configuration the subs sound horrible but as soon at i unplug one of the side it improves hundred fold. how do i fix this and if theres an easier or better way please let me know.
  • 631 Answers
You probably have a phasing problem. Reverse the speaker connections on ONE of the amps.
Posted on Sep 29, 2008
My light on my Kenwood Kac-8103D amp is constantly on red and nothing is coming out? How do I fix this
Check your fuse. Also make sure all your wiring and terminals are correct and not loose.
Dec 11, 2011 | Kenwood KAC-8103D Car Audio Amplifier
Kenwood KAC-8103D on and off problem
it sounds like the power wire might be grounding out somewhere that you dont know of it could be by the fuse link so I would say put electrical tape on any exposed wire on the fuse link first if that don't work try change the power wire.
Jul 19, 2010 | Kenwood KAC-8101D Car Audio Amplifier
Kenwood KAC-8103D short?
probably popped a diode in the amplifier circuit. The thumping sound is most likely power feeding back through the circuit, so it will have to be replaced professionally unless you have acess to the proper soldering equipment for IC boards. Hope this helps, even though it is bad news
May 29, 2009 | Kenwood KAC-8103D Car Audio Amplifier
Power lite on, no sound from amp after 1hr of usage
HI DUDE UR REMOTE WIRE FUSE IS BURNT .... REPLACE IT ... AND UR SPEAKER ... OR SUB TAKES LOT POWER FROM AMP .... ....
Apr 17, 2009 | Kenwood KAC-428S Car Audio Amplifier
Amp Turns off after 30 seconds of song play.
Check your ground and make sure it is grounded to metal in your car with no paint. Also, make sure you are running 4 gauge power wire. Another possible cause could be that the ohm load is too low on the amp. Also, if your car battery drops below 10v it will send the amp into protection.
Apr 15, 2009 | Kenwood KAC-8103D Car Audio Amplifier
Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Apr 14, 2009 | Kenwood Car Audio & Video
Can u fix a blew amp
yeahhh but you would have to send it in and hope its under warrenty. best bet do waht all the other jackasses do. sell that **** on craigslist
Apr 08, 2009 | Kenwood KAC-8103D Car Audio Amplifier
sounds very similar to something that has happend to mine. if you check the fuses in the amp and they are fine, i recomend replacing the fuse in the power wire. if you are using the glass tube type fuses, sometimes the soldering at the endcaps melts, but the filament doesnt pop. the fuse appears to be fine, but isnt. that happend to me a few times. i had to upgrade to ANL type fuses
Jan 11, 2009 | Kenwood KAC-8103D Car Audio Amplifier
Amp light turning off and on
if you see that happen you might need to your i c sound chip or your trasistor change then and check
Dec 11, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Protection Circuit
Yes, always a good idea to use a wire wheel and drill to get a super clean place for your ground. That was going to be the first thing I suggest. I would use a meter and see how many ohms the subs are at right now. It may be two low and there is too much current demanded form the amp at once. for a good sub wiring guide, go to
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html
Don't forget to leave feedback.
Jan 23, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Car Audio & Video Logo
65 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
