Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
1 in vertical line down the center of the TV
I have a intermittent vertical black line down the center my TV. When the turn the TV on initially it is no line....2-3 minutes of play and the 1 inche black line appears down the center of the TV. What should I do? Or, How can I fix it?
  • 308 Answers
SOURCE: Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Posted on Jan 01, 2007
  • 217 Answers
SOURCE: 2 inch black vertical line near center of screen
It depends where the line is centered most, to the right or left of the center, there are buffer boards that control the vertical video, on the bottom part of the unit if you take the back off and look at the bottom part of the set you will see these address boards, they are usually about 2 inches wide and could be labeled J or K, if the unit is High Definition then you could have these buffer boards on the top part of the unit also
Posted on Feb 17, 2007
  • 1153 Answers
SOURCE: Re: Hitachi TV Model 42EDT41 42 Inch
panel defect
Posted on Dec 26, 2007
SOURCE: my tv is hitachi 55pd plasma
Hitachi did in fact stand behind their product and resolved the problem. My hats off to them! Panel was replaced due to faulty ribbon cable supplying signal from one of the drivers. Unfortunately for my specific issue there wasno other solution as the ribbon cable in sealed inside the glass panel.
Posted on Jan 17, 2008
SOURCE: black line
I have the same problem. Very thin black line to the right of my screen though.
Posted on Sep 10, 2008
Vertical black lines in center of tv
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Vertical line faults to LCD TVs are given in detail, with screen-shots.
Mar 20, 2014 | Televison & Video
Why is my flat screen black?
problem in the vertical section, check for burnt vertical ic or bad capacitor near the ic.
Aug 30, 2012 | Westinghouse SK-32H240S Television
Screen turned black except vertical color lines in the center
good day your vertical ic is defective needs to replace look for qualified technician to fix your tv
Jun 20, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Black vertical strip on Hitachi plasma
seems like a lose ground issue from the vertical scan board which usually causes this problem. A scan board repair or replacement should fix this intermittent problem.....take it too your local repair shop before this problems spreads and the tv totally shuts down....
Nov 03, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
I have a LG 50PX1D-UC plasma TV with a black vertical line
You could have a Driver Board that has a loose connection or a Ribbon Cable that has a intermittent connection to the Plasma Panel, or a defective Plasma Panel. Either one could cause the problem and I would recommend only a Qualified Service Person to check it out.
Here is LG's Customer Service Number. 1800-243-0000. They could direct you to a Local Service Facility.
I hope this helps,
Sky Assoc
Oct 25, 2009 | LG 42PX5D 42 in. Plasma HDTV
Screen black no sound or picture with line in center
this is a common problem,the vertical hold has been damaged.dont leave the teli. on,the white line will burn the middle of the screen and leave a black mark. You need a new integrated circuit(i.c.) for vertical hold.
Mar 17, 2009 | Televison & Video
Black Line Down Center of Screen
Dry solder joints on the pins of the vertical integrated circuit may have caused this problem Tap each I/C lightly with a plastic screwdriver handle to find the intermittent one. It is the one with a heat sink attached.
Aug 10, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
53 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
