Cars & Trucks Logo
David Buswell Posted on Nov 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Seal broke i saw hole on right side of engine too many hoses and wires in the way its a silver arm looking piece coming out of the right side of engine i got some super glue and filled up the hole... i am not spending $1000 to have it fixed im gonna add some more heavy cement to it automotive grade boy it was leaking bad i was on I 95 when it happened it was a nitemare... SUPER GLUE saved me on my 1997 cadillac when i had a hose with a hole omg i panicked but used super glue and made it home over the delaware bridge 250 miles back to virginia SUPER GLUE saved the day!
Level 3:
  • Cadillac Master 17,130 Answers
  • Posted on Nov 22, 2011
Cadillac Master
Level 3:
Answers
17130
Questions
0
Helped
3635260
Points
52372
I am sure that this would help out in a temporary situation but when you are in for a longer drive it can result in a breakdown which you must be prepared of with consequences.
Superglue or cement can temporarily seal off leaks but over a time with heat and vibration this can fail. Hence I would recommend that based on the leak , you need to make sure that a proper seal is done even with an externalmetal plugging after a metal paste seal is done which could help out the case.
1helpful
Code p2006 and p2007 check engine light on computer diagnostic says Bank1 and bank 2 closed manifold is this an easy fix or what are my options
It could be an easy fix ,what make ,model an year vehicle . I know I saw a video on you tube on this very thing , the vehicle was a ford an it had a vacuum hose leak . Plus there was another one that had plastic pieces that broke an the control rod fell out of control arm. Check out some of these you tube videos . Installing New IMRC Bushing Ford Duratec Engine
1helpful
2answers
My daughter's 2002 jeep liberty is leaking water from the engine. It appears to be coming from what looks like a drain in the engine. I can't find any reference for this drain-looking tube in the...
Well, it all sort-of depends on what tube you are talking about and what kind of water is coming out of it. If you are seeing plain, clear water coming out of a tube that is located on the right (passenger) side of the vehicle on or near the firewall, then YES, water is supposed to be coming out of it when she is running her air conditioner. This would be the drain tube for the air conditioner that lets the water drain under the vehicle so it does not fill the cabin up with water.
If it is not plain water, like antifreeze (GREEN or PINK), then, NO, this should not be happening and you should get it checked immediately.
Engine coolant leaked out. when i was driving i smelled the buring of engine coolant then saw the smoke from my hood. so i pulled in to a gas station turned my truck off got out then saw a huge puddle of...
Check to see if the water is coming from the center of the front of the engine or if it is coming from one of the sides of the front of the engine. If it is from the side it is probably a busted hose and cheap and easy to fix. If it is coming from the center, locate the water pump and look at it from the underside there is a weep hole there and if it is leaking from that hole the water pump needs to be replaced.
On the bottom of the driver side windshield wiper's arm where the bolt is. There looks like a piece is missing to seal or cover the hole to where the wipers motor is. It look like a giant washer or plug....
hi what you have here is the damper ring, this is the rubber bit that goes between the body work of the car, and then it seals on the wiper connection then you have a flat washer on to of that then the hex nut...hope this helps
Steam from antifreeze coming from right side of engin
I would check the hoses in that area. It maybe the the water pump bearing shaft seal. There is usually a small drain hole towards the bottom of the pump, that will leak anti-freeze when the seal goes bad. With an inspection mirror, you may be able to see if anti-freeze is leaking from the pump.
3answers
Water leak at front of engine very small amount maybe a gallon every 2 weeks on 5.3 suburban 2002
check your hoses for poor condition and loose clamps. Check the gasket around your water pump as well.
3answers
Water on passenger interior floor
Has it been raining where you live or washed your car recently??If not more than likely its your AC drain hose either clogged or damaged. Its located under the passenger dash. Hopefully this helps
3answers
Unsolved Problem!
Have you looked at the gas or gas tank. It could be full of water. Your specific pump could be sitting up high where the gas water line settles after a period of time. Try some dry gas and run the tank out.
11helpful
Where is the ac drain hose
Normal 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} -- open the driver's door
-- locate where the air conditioner blower box is attached to the passenger side of the firewall – see photo #1 – look to the immediate right at the top of the gas pedal arm
-- condensation flows toward the front of the vehicle through the firewall at the leftmost edge of the air conditioner blower box – drain channel
-- open the hood and stand next to the front wheel on the driver's side
-- look down at the firewall over the battery and to the passenger side of the brake master cylinder – see photo #2
-- locate the small diameter metal tubes running horizontally and attached to the engine compartment firewall
-- locate the hole in the engine compartment firewall panel behind the small diameter metal tubes
-- this hole leads to the drain opening in the air conditioner blower box mounted in the passenger compartment
-- follow the brake tubes as they run from under the vehicle and turn toward the front wheel on the driver's side
-- locate the hole in the engine compartment panel behind the brake tubes
-- insert a short length of stiff wire into the hole through the engine compartment panel to unblock the drain hole
How to change the Belt Tensioner on a 1994 ford escort wagon.
On the right hand side of the engine find bolt in the center of the tensioner arm, this is the only bolt that holds it in place. Look directly across from this bolt and you will see a hose, the power steering resivoir hose is clamped here with a 10mm bolt, remove this bolt. Remove tensioner bolt and lift hose up to get the bolt out. When installing new tensioner, locate small round hole in tensioner mount on the engine, insert small pin on back side of the tensioner arm in this hole, then insert bolt and tighten, install the hise clamp bolt, and belt. Hope this helps, let me know.
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
