Magnavox 60" Rear projection screen convergence. Just changed coolant & Picture is off?
Hi All,
I have Magnavox 60" Rear projection screen TV Model # 6P6030 W101. Just received it from relative. Picture was great on it, but the characters and people on TV would just glow very bright. I read up on this and found my lens had a lot bacteria growing in the coolant. I changed my coolant carefully. I took out each lens one by one, cleaned and changed each one carefully. I put everything back in the way it came out, marked all my wires where there should go back. I turned on the TV, the glow is gone, pictured looks 100% better, but everything is 3D?!? I tried the convergence. The red and blue moves up and down, left and right just fine, but they stop short of being aligned perfect on the cross hair. It's like the lens need to be moved or something?? Please check the link below to look at my pictures.
http://i157.photobucket.com/albums/t75/twatson7805/Magnavox%20TV/TV003.jpg
http://i157.photobucket.com/albums/t75/twatson7805/Magnavox%20TV/TV004.jpg
http://i157.photobucket.com/albums/t75/twatson7805/Magnavox%20TV/TV005.jpg
http://i157.photobucket.com/albums/t75/twatson7805/Magnavox%20TV/TV002.jpg
I so thought I had this and was going to be a great new TV for the family, but it just created another problem. I'm very handy and needs some further help!
Thank you in advanced!!
Chris
2 Suggested Answers
  • 5 Answers
SOURCE: magnavox 60
It's probably the magnets on the neck of each CRT that moved since you removed them or the CRTs weren't put back in the exact orientation . Use a white paint pen to mark each one as they are now. If there's a clamp or two metal rings that locks them in place you can try rotating them as a group (their location up and down the neck is also critical).  If not you will have to adjust them individually and then do a complete convergence adjustment. That's a big task. Good luck.
Posted on Sep 30, 2008
I have a Philips Magnavox 9P6034C 60 in. Rear Projection Television the whit bulb is gone out where do i get another one
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 27, 2011 | Philips Magnavox 9P6034C 60" Rear...
Model # 7P6033W101/ my tv is in need of major service. I believe that I need picture tube replacements.How can I get service.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 21, 2011 | Philips Magnavox 9P6034C 60" Rear...
Picture stays red with blue background and adjustments make no difference
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 17, 2011 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox 55" rear projection tv problems
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 11, 2010 | Philips Magnavox 9P6034C 60" Rear...
My 60 inch Maganvox tv is blurry and the letters at the bottom are blurry. Can;t hardlt make out the picture now.
Replace STK convergence chips there are two next to the heat sink.Unsolder old and solder in the new.
May 21, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture arches down at the top and arhes up at the bottom
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 08, 2009 | Philips Magnavox 9P6034C 60" Rear...
Red "aura" in the middle of my 55" Phillips Magnavox
  • Screen looks 3D
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips rear projection color and pic problems
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Mar 22, 2008 | Philips Magnavox 9P6034C 60" Rear...
60 inch phillips magnavox projection tv
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
