Question about Targus Chill Mat PA248U Laptop Cooler
Targus notebook cooling chill mat. One fan has stopped running after less than 2 months. Can you help
  • 2 more comments
  • Anonymous Sep 29, 2008
    after about 3 days from my purchase, one of the blades of the left fan broke off. about 3 weeks later the right fan made a rumble noise. then after about a week, the right fan stopped working and the left fan is running weaker than normal.
  • sharbear36 Nov 28, 2008
    Mine made it about 3 months too, I was looking here for a solution but apparently there isn't one. I guess no more buying Targus if they can't make a fan right
  • Anonymous Jan 06, 2009
    had to wiggle wire to start fan now it won`t work they are an expensive piece of junk
  • Anonymous Mar 28, 2014
    electric shock using lap chill mat targus
I have the same problem, and I looked inside to see the cause- the interior part for the power is poorly made and comes loose. That's the reason for the one fan not working and it getting weak. Sometimes wiggling the cord or trying to stabilize it will help. But, as I learned the hard way, it will eventually break. Its a poorly made product, and I've had mine about 4 months now and it completely broke today. I opened it and did my best to stabilize the part, but... it will break. As best as I can tell, its a poorly made product and there is no permanent solution.
Posted on Oct 24, 2008
    Sergeant:
  • 281 Answers
I had a similar problem. What I did was opened up the case and spliced and connected the power cord to the USB connector permanently. Not an issue since.
Posted on Aug 31, 2009
What are the other ports used for, and can I use them to run the fans?
Do you mean the USB-ports on your laptop? If so, than yes, you will need one free USB-port to connect the Chill Mat to.
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
The little insert in the usb port on my targus dual fan chill mat has become loose. How do I re-insert it and keep it from becoming loose again?
Tawny, If port still functioning, use 2 part epoxy to secure port, be care, no glue inside port.
press the helpful button
Laptop chill mat getting lould and fans needs to be cleaned
It will probably be more efficient and easier to replace the cool mat. They are very inexpensive.
Mar 28, 2014 | Targus Computers & Internet
Targus chill mat won't work
it is definatly either a wiring issue or a cpu issue
Mar 18, 2014 | Targus Chill Mat PA248U Laptop Cooler
Targus chill mat cleaning fans?
You could use a vacuum with a hose attachment as well to **** the dust out.
Jun 26, 2012 | Computers & Internet
Lost the targus notebook chill mat power cord (usb from computer to the mat). Where can I find a replacement?
hi this can be purchased from somewhere like radio shack specs are Output: 5V 2000mA, centre is + positive so really just your standard adaptor will do, this also comes from the targus site hope that helps
Oct 02, 2010 | Targus Chill Mat PA248U Laptop Cooler
Targus Chill Mat Fan On Fritz
The fan rotor is stuck due to accumulation of dust. Take out the fan and clean it. Put a few drops of alcohol or lacquer thinner on the rotor/bushing assembly while manually turning its blades to loosen the hardened dirt until the fan freely spins like the good one. If it does not work, replace the defective fan if spare is available.
Aug 19, 2009 | Targus Chill Mat PA248U Laptop Cooler
Chill mat
i have 1 as well and it broke too. this is http://computers.pricegrabber.com/laptop-accessories/m/1754767/
right?
if its the cord's thats broken, its most likely the switch, more specifically the soldering where the wire connects to the switch is prolly broken. i just sawed my switch open w/ a knife, and took a look. now if a wire is loose in the switch, u can either solder it back on, or (in my case i always have the fan on anyway cuz of my **** dell computer overheating) rip the wire off the switch completely and just connected it w/ aluminum foil.
Mar 24, 2008 | Targus Chill Mat PA248U Laptop Cooler
Computers & Internet Logo
912 people viewed this question
Top Targus Computers & Internet Experts
dhnguyen
J John
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
