The picture does not fill the screen on most channels. Some of the HD channels do fill the screen, but no analog stations.
    President:
  • 2,712 Answers
There is an option for screen size from within the menu. You can choose letterbox or one of the other settings thru the remote. This is common, and is a result of the way the particular channel is broadcast, and nothing wrong with your TV set.
Posted on Sep 28, 2008
Why will my JVC blackcrystal 3001 series led not get a full screen picture on analog stations
There is a compatibility issue here. The format is not matching properly with the settings. You may have to study the operation manual of both and try changing the settings. If not, this is indeed a problem only the box top.
Jul 17, 2012 | Televison & Video
Can't get picture to fill the screen. Black bars
U have a CRT tube analoge standard tv,this feature will not work for a CRT analoge standard tv.Zoom in and out,picture sizes like 480,720 and 1080.The analoge tv can't get the tv signal ranges beyond 480i that why u have black sides bars picture,if u have a HD TV like a LCD tv or Plasma tv,than the Zooming in feature will works.
May 24, 2011 | Televison & Video
On some HD channels that do not go to the full screen the top of the screen is not filled with a picture
That is a problem with all HD service, not all the content on HD channels is infact HD so it doesn't fill the screen. Only thing you can do it zoom the picture in or put up with it.
I think its almost criminal that cable and sat companies charge us for HD channel and don't play all HD content. But such is life.
Cheers,
Jan 06, 2010 | Panasonic Televison & Video
With converter box only receive 2-3 channel
They have powered antennas that give you more stations. I added a HD antenna I bought off ebay for 19 dollars and I get 10 stations. Please give me good rating It means a lot to me.
Jul 05, 2009 | Insignia Digital-to-Analog Converter for...
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
Can not get hd channels on my new tv..
First of all, digital/HD signals are broadcast at UHF frequencies. You need to know if you have an UHF antenna and, if you do, that it is pointed to the TV stations broadcasting HD.
Second, since most TV's have a setup mode that automatically searches for channels that are able to be received, go to that "Setup" menu on your TV and start the auto search. It will list both analog and digital stations. Note that the analog channel may be, for instance, Channel 39 but the digital channel will be Channel 39-1. Tune to the "dash 1" channel.
Dec 30, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Can't get cable stations
you have to go into the menu and set for cable then scan for active stations.
Mar 15, 2008 | Televison & Video
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
