Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Automatic ice maker quite working after 7 day power outage
    President:
  • 2,712 Answers
Check to see if the power cable is ok. If your unit has a fuse, you may need to replace that. Looks like the power outage might have fuzzed up the power circitry. If neither of the above works, then you may need to get the machine serviced.
Posted on Sep 28, 2008
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Ice maker quit working. I found water on the floor outside freezer side. This happened after a power outage and the ice maker hasnt worked since
The ice maker is freezing sound like it turning but not dumping and new water is comming in and no where to go except over the top. A new ice maker is around 100.00 Sears had them on sale recently for 49.00 find a used appliance store and maby pick one up for ten or fifteen dollars. You can install it the just plug in and hang by two screws.
Apr 26, 2010 | Kenmore 21.8 cu. ft. Side-By-Side...
If the water filter needs to be replaced will the ice maker automatically quit?
Good day,
Possible if creating a serious enough blockage, and you were experiencing a gradual loss of output.
If the failure was abrupt and quick. No. Ice maker, water valve, water supply, fill tube to ice maker iced up, and too warm a freezer, will cause loss of ice maker production.
Nov 11, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Ice Maker not working
Hi!!! your ice maker might have frozen over and gears are stuck..remove your ice maker and unplugg from the frig clean it and all is resolved..
Jan 04, 2009 | Refrigerators
Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Dec 24, 2007 | Frigidaire FRS23KF7AB Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
162 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
