Question about Haier Refrigerators
Compressor is hot - Haier Refrigerators
    Sergeant:
  • 304 Answers
THEY ARE SUPPOSED TO BE
Posted on Sep 29, 2008
Hot WL611200 air compressor
Campbell Hausfeld WL611200 Oilless Air Compressor This is an oil less compressor. Yes compressors do get quit hot. That's normal. Just keep the fins clear.
This
May 21, 2014 | Campbell Hausfeld FP2028 1 Gallon Air...
PU8YAKD-TH MITSUBISHI UNIT COMPRESSOR INTERNAL PRESSURE BY PASSING
This sounds like the compressor may have been overcharged. Some compressors are designed to release this excess pressure instead of exploding. Use a combination gage to check the high side pressure before and during operation. Since the compressor's lubricants are contained in the refrigerant, it can get hot from the loss, but will also run hot and draw high amps from an overcharge.
Sep 28, 2013 | Heating & Cooling
Compresser is hot, will not turn on.
Unfortunately, I can tell if the compressor is bad by feeling how hot it is. You should be able to touch it and will be almost a bit cooler than hot. If it is not running and your compressor is really hot, I am sorry but your compressor is bad.
Aug 29, 2010 | Refrigerators
My freezers compressor is getting very hot and the freezer is not freezing
Fridgidaire Upright Freezer appears that the compressor is getting hot enough to burn ( serious discoloration) the linoleum below the freezer.
The compressor is hot to the touch.
Freezer is working just fine.
What to do?
May 15, 2010 | Frigidaire FRS26R4A Side by Side...
Compressor is getting so hot it is smoking
Make sure you are running compressor oil in it. Not motor oil.
Apr 23, 2009 | Campbell Hausfeld 26 - Gallon Air...
My refrigerator dosen't cool or freeze
the hot piece is the compressor.the clicking is the relay trying to start the compressor.generaly when im out on a service call and the compressor is hot and relay clicking the compressor has failed internally.because if the relay was clicking but the compressor was not hot there was a chance only the relay was bad and not allowing power into the compressor.but because the compressor is hot that tells me the relay is letting the power to the compressor but the compressor cant do anything with it because it locked up and its absorbing that power getting hot and then clicking on overload you could try a relay but i don't think it will help. God bless ,tom
Jan 23, 2009 | Kenmore 50522 / 50524 Side by Side...
Water is hot on both cold and hot side of my water cooler. water bottle on cooler is extreamly hot.
are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
Oct 06, 2008 | Whirlpool Refrigerators
Not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Sep 24, 2008 | Hotpoint HSS25GFP Side by Side...
Freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Aug 20, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerators Logo
77 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
