Question about Cameras
I have a Kodak easy share # Z710 and I can't all of a sudden can't delete the pictures on the memory card. My camera says that the memory card requires formatting. Can you explain to me just how to do this, since I sure can't find any directions in the manual. I've had the camera for almost a year and this is the first time this has happened? Does this mean my memory card is shot? Please inform...............Jeff
Go to the "Set up" portion of the Menu, choose "Format." Note this will erase all the data on your memory card, so you want to download the photos someplace first.
Posted on Sep 29, 2008
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
It tells me I have a driver problem
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
May 15, 2014 | Kodak EasyShare Z710 Digital Camera
Kodak easy share wont delete or scan to the left to view pics
In order to solve the problem you need to transfer pictures from the internal memory to the SD card and thereafter you will be able to delete the pics in the internal memory.
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  1. On the camera, press Review and then Menu.
  2. Select Image Storage.
  3. Change to Internal Memory.
  4. In the menu listing, scroll down to Copy, and select OK.
  5. Select a single picture, or select All.
  6. When you have finished copying pictures, reset the Image Storage location to your original setting.
Dec 22, 2009 | Kodak EasyShare CX7300 Digital Camera
I cannot take new pictures after inserting a new memory card.
HAVE YOU TRYED PUTTING THE PICTURES ON YOUR COMPUTER SO YOU DONT LOOSE THEM BUT THEN YOU'LL ABLE TO DELETE THEM OFF YOUR CAMERA ? TO RELEASE THE INTERNAL MEMORY YOU'LL HAVE TO DELETE THE PICTURES MOST CAMERAS HAVE LIMITED MEMORY AND IF USEING A SETTING LIKE HD PICTURES WILL USE UP ALOT OF THE MEMORY TRY SETTING YOUR CAMERA TO TAKE PICTURES IN A SMALLER FORMAT LIKE VGA OR A SMALLER RESOLUTION
Mar 30, 2009 | Kodak EasyShare Z710 Digital Camera
WHERE is the port to put my memory card from camera into my HP?
HP Laptops don't come with a built-in card reader.
You have two options:
  1. Use the USB cable that came with your camera to download your pictures. This plugs into your camera right next to where your card goes. Your computer will recognize the camera as a "removable drive". Click the Start button, click on My Computer, and click on the drive (usually E or F) that is called "Kodak EasyShare").
  2. Go to Best Buy or similar and purchase an HD Card Reader. These cost about $20-$30.
Mar 12, 2009 | Kodak EasyShare Z710 Digital Camera
I deleted pictures i want back
Once u have deleted the pictures from the
memory card u can't get it back.
thanks..
Feb 01, 2009 | Kodak EasyShare Z710 Digital Camera
Error uploading pictures to kodak easy share gallery
Uninstall the easyhare software from the control panel then run the clear utility program at www.kodak.com/go/clear
Nov 24, 2008 | Kodak EasyShare Z710 Digital Camera
Cameras Logo
108 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
