Question about Toshiba Satellite P105-S6104 Notebook
Internet drops my toshiba laptop times out when i am using the wireless but works fine when hooked up hardwire , but other laptops work fine , and does the same thing at work and at other locations i use it .it usually drops after about 15 or so minutes of using it
    Genius:
  • 1,550 Answers
It looks like you need to configure your wireless settings .Have you tried configuring settings ?
Uninstall the wireless driver and re- install the driver for wireless with proper updates .
Thanks for using Fixya
SAM ANDERSON
Posted on Sep 28, 2008
    Problem Solver:
  • 10 Answers
Compare all your internet connection settings to the laptops that work well. Mirror your settings to match a laptop's that is working properly.
You might also want to re-install your internet drivers. Go to your Toshiba site. They should have all the drivers for your model.
Two toshiba laptops, one less than a year old running win7...the other 3 yrs old runnign xp. both worked fine connecting wireless to my router sat. sun the win7 machine said the dns server was not...
Did you press a button (or move a slider-switch) on the WIN7 laptop, to "disable" the wireless adapter?
Can you login to the web-server "inside" the wireless router, and look at the "log-files" that the router keeps of "recent" events (such as connection-attempts from wireless devices), to see if there is any useful information in those logs?
Does the WIN7 laptop connect to _any_ wireless network (Starbucks, university, shopping mall), or does it fail ONLY when connecting to your wireless router?
Have you tried a "factory-reset" on your router, just in case that it might be the problem?
Feb 21, 2011 | Toshiba (PA3212U) Wireless Adapter
Can I hook up a wireless router with only laptops
you need a pc or laptop using a hardwired connection prior to using the router, hence the name router, it routes the hardwired conenction and broadcasts it wirelessly.
Dec 29, 2009 | Belkin (F5D7230-4) Router (587009)
Slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
Hi I have a Dlink DIR 415 Wireless router that is linked to a Comcast modem. I am running a laptop computer off a dock from the router and my kids run xbox 360 wireless. However, I just bought a new...
When you hook it up do you see an error in the LAN status is your system tray?
Depending on the status you may proceed with checking each component needed. Use this for reference http://www.microsoft.com/windowsxp/using/networking/maintain/troubleshoot.mspx
Jul 22, 2009 | Computers & Internet
Problem connecting to router
Log into the Belkin router and make sure that the DHCP services are running. If it is, and you still are not getting addresses, perform a factory reset of the router. There is a link in the web management console to do this.
Jun 22, 2009 | Toshiba Satellite Pro A200-EZ2204X...
One of five PCs not connecting to Belkin 54G router
I would connect it to the router using a lan cable to verify that it will get a IP address and connect to the internet. Write down the IP information and make a static wireless connection with that info. It should work hardwired and wirelessly with this info. If it doesn't work wirelessly you may have a bad wireless card or you may find that their is already conflicting static IP info in the connection that has to be removed. Make sure that on your internet protocol (TCP/IP) properties that you have selected "Obtain an IP address automatically" and Obtain DNS server address automatically". Clear any settings that you may see there.
Jun 22, 2009 | Toshiba Satellite Pro 6100 Notebook
Using HP laptop running Vista wireless intranet connection to HP desktop running xp and desktop hardwired connected to HP Officejet 6110. Can not get laptop to print on network. All internet and other...
The printer needs to be installed by you as "Adiministrator". When installing the printer you need to hold down the "Alt" button when clicking n Add Printer function. It will then give an option of installing as Administrator.
May 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Wireless Network gone from Toshiba Laptop all of a sudden.
Please try to scan and connect to your wireless network at a distance of around 6 to 7 feet from the router. This might help if there are any interference issues at play.
Also, you could manually create a profile for your wireless network on that laptop and try.
Alternatively, you could update the drivers for the adapter on the Toshiba laptop and check it out.
Please let me know if the above helps. Also, kindly rate the solution, if it helps.
Thank you.
With Warm Regards
Venkat
May 17, 2009 | D-Link DIR-625 (790069292637) Wireless...
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Modem reboots when using wireless
Did you try upping your lease time and see if that changes things.
The lease time is the amount of time before a DHCP request a new IP address.
Ususally it get the same, but if it is malfunctioning it can cause problems like this.
Jul 15, 2008 | 2wire (1000-400108-001) Router
Toshiba Satellite P105-S6104 Notebook Logo
100 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
