Question about KitchenAid KAWS750L Top Load Washer
Kitchenaid KAWS750JQ3 Top Load Washer
The machine will fill, start to agitate, then stop. It will then agitate for a few seconds and then stop. There could be upto 10 - 15 minutes between each time is starts. This goes on for upto 90 minutes. Then, once the unit gets to the spin cycle, same thing happens. Spins for a few seconds, stops, delay, spin, stop, delay, etc. Have tried to manually advance the timer, but that does not work either. Thoughts??? Oh, the wash will usually finish in about 2 - 3 hours - lovely huh????
  • 943 Answers
Hi thanks for the question . Yes lovely huh. but that's how that washer operates .thanks the appliance doc
Posted on Sep 28, 2008
    Sergeant:
  • 409 Answers
make sure that the program is not on the "Intermittent Agitate Program". that would be the cause of the delay.
the other issue would be the timer itself. the timer is mechanical, so once the contact on it is corroded, it will only function intermitently or not at all.
please let me know if i can be of more help.
thanks
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
The agitator works intermittently
Replace the agitator dogs (4 small white/beige plastic parts) inside the agitator, they are worn.
The part number is 80040.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
My Kitchenaid washer stops on the rinse cycle...
Do you have an age of the machine and model number? Is there a "spin only" cycle? On older machines, there was a center knob you could slowly rotate, one click at a time, to advance it through its cycle. Can you do that? If the unit is agitating, I don't believe the belt is your issue. Age and model please.
Jul 31, 2017 | KitchenAid KAWS750L Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
Kenmore 90 Series Washer
Maybe. Sounds like the motor is not agitating in the other direction??? There is a controller on this type of machine which handles the starting...direction of the motor..this is by far the most common for your description.
next would be the timer or transmission.
to check trans..grab top lip of bowl it should be locked in both directions. tilt machine back..you should be able to spin the pulley in both directions it not its the trans
I'm sorry bout the flow of this...not used to doing it like this...think i'm slowly getting better????
Jan 04, 2008 | Kenmore 24032\24036 Top Load Washer
Begins to agitate but stops
The motor could be drawing too much current and causing the overload relay to trip. You will need to get an authorised techinician to test the motor.
Nov 01, 2007 | Kenmore 93702 Top Load Stacked Washer /...
KENMORE TOP LOAD WASHER
i have the agitator dogs, but my agitator is not turning. Can you help me in getting it off. kenmore model 11022954100. please help !!!!!! wife is tearing me up!
Oct 29, 2007 | Kenmore 22422 Top Load Washer
KitchenAid KAWS750L Top Load Washer Logo
340 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
