Question about Maytag MZD2766GES Side by Side Refrigerator
Psd262lhez performa side by side
Does not freeze, no ice, and is barely chilled on refer side. I have turned up all the settings, unplugged and replugged. I had a power outage and thought maybe there was a reset button or something. The first thing to go was the ice maker prior to power outage. water dispenses just fine . no ice whatsoever. No leaking anywhere. No frost anywhere. Not really cold anywhere either. This unit is seldom used, so I couldn't really say how long the icemaker has been out. Thanks for any help or suggestions!
  • homerosgh Feb 17, 2009
    my refrigerator was working well then all of the sadden stop working with no signs that showed it was going to break. now it doesn`t cool at all.It is about 4 years old and guaranty expired already.
I got one of these in my shop. I am tech, call me for info. steve 320.963.3580 MN
Posted on Oct 09, 2008
I have a maytag plus side by side door refrigerator that will not make ice anymore what do I do to get it to make ice again will you please e-mail me and let me know. Thanks
Posted on Oct 11, 2008
I have a Samsung side by side refrigerator Model No: RS21DCSV. The water and ice dispenser are working. However, the water is no longer chilled?
Water is stored in a tube bundle located behind the crisper drawers (bottom, back of the refrigerator) and is chilled to the temp of the refrigerator (perhaps 40 degrees F). This tubing holds approx. 16-32 ounces (less than a liter) and incoming water pushes the chilled water to the dispenser, but also begins to warm the output water temps.
The only way to get colder water is the set the refrigerator to a lower temperature. But be careful that the temps are not so low as to cause other food items to freeze.
Sep 30, 2016 | Samsung Refrigerators
My Kenmore side by side fridge isn't cooling hardly. Feeling the suction and discharge lines I think it's low on freon. How do I charge it?
Well I have to go, so I can't wait for your reply for more info. Basicallty what happened to me was the freezer became very good at freezing. The problem with modern freezer/fridges is that there is only one cooling system, the freezer. The freezer chills the other side to chill the refrigerator. Something was blocking that vent into the fridge side. Turns out it was ice blocking the vent into the refer side. It happens when it is humid and the kids to "shopping" in the fridge and leave the door opened for extended periods of time.
If you are blocked by stuff in your fridge, move it away from the vent. If nothing there, you'll need to get ready for a bit of time. Side-by-side freezer/fridges, typically the freezer is on the left. So, open the fridge, somewhere near the back about 2/3s of the way down, just above the vegetable bin, on the left side. Remove the cover, if something is stuck in there, gently try to remove it. If it is ice, like I had, you should remove your vegetable bin and meat bin and unplug the unit (to prevent shock as water will be everywhere. Be sure that your overflow tray (under the unit) is empty. Next is to make quite a bit of boiling water (I ended up using just over a gallon). If you are at the point where you can't get the cover off, you'll have to use a baster to melt the ice that is holding your vent cover on (that is where I started). Then you can start working on the ice. You need to keep putting water in until you get hot water in the overflow tray. Replace your food and don't slam the fridge control all the way to the coldest setting, you could end up freezing your meat and vegetables.
The repairman came and told us, he could do this for us for $200 or we could do it ourselves. He would have done the exact same thing.
Feb 05, 2014 | Kenmore Refrigerators
Emerson ice maker not freezing ice, making small cubes and they are soft and mushy.. seems to not freeze ice solid and takes forever to drop ice
When was the last time you cleaned it by running ice machine cleaner through it. After a period of time algea, or slime will form on the chill plate where the ice is made. Sometimes its invisible to the eye, but it doesn't mean its not there. When this happens the machine will freezse the water, and when the ice tries to slide forward to the cutting grid, it catches on the chill plate. There are no sensors in the machine to tell it that this is happening and so the machine moves forward and starts running more water across the plate, which in turn runs across the ice caught on the chill plate melting it and using it as a ramp to fall into the bin melting the ice there as well. So, try cleaning it before taking any further steps, then if the problem persist feel free to get in touch.
May 15, 2012 | Emerson Im90 Portable Ice Maker
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Water is not cooling
Hi: This Wide by side is like all other side by sides as to how it stores the water. Storage will be behind the crisper or meat keeper in the form of a coil of tubing or a bladder to store the water. Pretty simple. The length of tubing running from the storage to the dispenser will not be chilled. Some refrigerators do this better than others. Try setting the ref. or meat keeper a little colder. Watch your vegetables so they don't freeze. Rare, but it's possible... Older homes (before dispensers,) when fridges just had ice makers, would tap into the hot water line for ice to freeze faster and be clearer. I know this sounds crazy but it's true. I lived in an older home and in the winter the hot water would always freeze first. I know this solution sounds lame but there really is nothing much to go wrong with the water chilling. Pull your meat keeper out and look at the reservoir and see how cold it is. Good luck, Jeff
Jun 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag Refridgerator and not cooling or freezing
sounds as if perhaps the overload replay has burnt up on the compressor, you can see it by removing the back cover, unplug unit and remove the starter from the side of compressor. if burnt up or melted youll need to replace it.. before you do i would call the manufacture with model and serial theyve experienced issue with some of these depending on model and serail they may cover repair
Mar 10, 2009 | Maytag MSD2651 HE Side by Side...
Need Owners Manual for Kitchen Selectives Wine Chiller (1 Bottle)
A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, turn on and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
I just bought one at Goodwill for $4 today and was looking for the instructions as well. Hope this helps!
Jan 16, 2009 | Kitchen Selectives CM-202 Coffee Maker
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Cuisinart ice cream-frozen yougurt maker& sorbet maker CIM 60 series
I have the same problem, but it seems that it has gotten worse with time. When I first bought this product 6 years ago it worked fine, now the bowl won't freeze entirely and it has been in the freezer for two days (at the lowest freezer setting). I am wondering if the freezer bowl has a life span.
Aug 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Maytag MZD2766GES Side by Side Refrigerator Logo
897 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
