Question about KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher
No power at all
Our dishwasher just stopped one day. all lights are off and nothing seems to get them on. I pulled it out and checked the outlet and it is working. Any fuses or other easy things I don't know about that might get it working? Thanks
  • skyxson8903 Feb 08, 2009
    I have the same problem with no motor noise Although I don't know the model number (lost paperwork), it looks very similar. It is plugged in and we checked circuit breaker...still dead as doornail. How do we access main control panel? What else could the problem be?
    Sergeant:
  • 409 Answers
can you hear the motor running? then it's the main control board. if you can hear it, that means you have power and i would check the keypad on the very front.
please let me know how it goes.
thanks
Posted on Sep 28, 2008
Samsung dryer without power
What is the model number??
Jun 27, 2013 | Samsung Dryers
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
There is a fuse on power unit, that should be tested first, check also a different outlet.
Aug 09, 2008 | LG Dishwashers
Kenmore 66517514202 dishwasher has no power dead no lights nothing
Does the wiring come up through the door at the bottom to the control panel? Check for a broken wire
May 21, 2012 | Kenmore Dishwashers
My dishwasher (Model # FDB520RHB0) is not quite 2 years old. We had the water pump replaced a few months ago because it had been making a grinding noise. Then we tried to run it a few days ago and it...
Did you check the outlet with a voltmeter? If you did and have 120Volts then it sounds like your latch switch could be defective which would kill the power to the unit.
But remember that in most houses that the outlet under the sink is wired for a garbage disposal where the top outlet is controled by a switch and the bottom one is wired for the dishwasher.
Jul 27, 2011 | Frigidaire FDB520RH Builtin Dishwasher
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
Water staying at the bottom of the washer.When i close the washer an press start the inlet/drain light comes on and nothing else happens.Miele G 692 SC PLUS
Your drain outlet is blocked , pull all the filters out and then check nothing is stopping the impeller from turning. You have to bucket out all the water first of course. It can be a toothpick or just some gunk,
Mar 25, 2010 | Miele 24 in. G692SC Plus SS Free-standing...
Seems to have no power.
check where wiring connects to machine,make sure correct voltage is present at connection block.also check for blown fuse at connection block area.
Oct 16, 2009 | Whirlpool GU3600XTS Dishwasher
I have no power on my dishwasher. I ran an extension cord to another outlet that I know has power and still nothing. I don have any led lights or anything. Can you help. GE model # GHDA960K03BB. Thank...
Few components may cause power failure to your Dishwasher.
1. Disconnect your power plug from the socket outlet.
2. Trace the cord to where it connected to your dishwasher.
3. Tight those connectors firmly .
4. Plug back your dishwasher power cord .Start your dishwasher.
If nothing happen, check if control board came with fuse or bimetal. check the continuity of the fuse., You may also check your latch assembly.If no power still change the console or the control board.
Jul 26, 2008 | GE Dishwashers
Inlet/outlet light comes on
Machine is possibly not filling with correct amount of water if this light comes on early in the cycle
Aug 15, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Open Questions:
See all KitchenAid 24 in. KUDI01ILBS Stainless Steel Questions
KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher Logo
120 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
