Question about GE WHRE5260E Top Load Washer
GE WWRE5240D1WW transmission seal
Need help! How easy or difficult to replae the transmission seal in my top load GE washer? Leaving dark grease type spots on clothes. I removed the agitator and found grease all over the under side of it. Also the threaded shaft it sits on is loose.
  • 121 Answers
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
Water leaks out the bottom through through the clutch when filled and running
There are gaskets and shaft seals that can leak. Not an easy task. On my GE washer, I had pinhole leaks near the transmission mounting flange. I used JB Weld epoxy and sheet metal screws to seal the leaks. and of course changed the gasket. That was 8-9years ago. So my investment in time and transmission paid off. A bright light under the clutch and a dark room may show what's leaking. you may be able to temporarily seal with a window caulk from the top or bottom Or a bathtub waterproof sealant. If it's the rubber gasket, a rubberized sealant "may" help. I guess it could also be the pump. I use paper towels tied around things like drain pipes to find leaks, or make sure my work is not leaking.
Mar 12, 2015 | Maytag Centennial MVWC6ESWW 4.0 cu. ft....
Top load washer leaving flaky black spots on some clothes. This doesn't happen with every load just randomly, but becoming more common. It doesn't damage clothes if I catch it when they come out, I...
It could be a sign one of the rubber hoses is eroding internally or perhaps a bearing is failing.
If a hose the black spots will be easy to remove, if grease, wiping the spots will spread them and they will be harder to remove.
Oct 08, 2017 | Washing Machines
Grease inside washer
"When the seal starts to fail, this oil floats up into the wash water in the form of small black drops. The stains are almost impossible to remove from clothing. Also, as the oil is leaking up, hot soapy water is leaking down into the transmission, which will eventually cause it to fail. As I recall, the seal wasn't difficult to replace, but to get access to it,you basically have to disassemble the whole machine.
Nov 20, 2010 | GE WBSR3140DW Top Load Washer
GE WSXH208FWW washer leaving spots on clothes
If you are getting round dark spots on your clothes after washing, the problem would be cause by a bearing seal leak. What happens is water leaks pass the seal into the bearings, and the grease leaks back into the wash water. To fix it would require the machine to be literally taken completely apart to get to the bearings. Very costly to repair. Sorry.
Aug 24, 2010 | GE WSXH208A Front Load Washer
Leaving black residue (spots) on clothing
Black spots usually come from the agitator shaft bearing seal which will, when worn, allow oil from the transmission to seep into the wash. Replace the seal, and maybe the upper bearing if the shaft itself will move visibly from side to side in various directions. If the machine is still under warranty, take advantage. Hope this helps!
Apr 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Hi! GE top load washer model number wwse5240 is leaving grease stains inside the machine after laundering and of course on clothes. Not sure how old this machine is.
Your transmission is leaking oil. It's probably 10 to 15 years old for the transmission to be leaking. It can be replaced but it's not a small job. Part 320 in this diagram is your transmission. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5224109&diagram_id=22255027#d22255027
Jan 30, 2010 | GE WDSR2080D Top Load Washer
Leaking grease
All washer machines have a "transmission" - just like a car these units have oil in them and when the seals that protect the oil from going to our clothes is breake, oil finds its way to your clothes.
Transmission needs to be replaced.
Aug 18, 2009 | GE Profile WPRE6100G Top Load Washer
MY GE WASHER PUTS WHAT LOOKS LIKE GREASE SPOTS ON MY CLOTHES.
sounds like the transmission seal has started to leak. yes the transmission, all washers have these and at a certian age and usage the seals will start to leak grease into the drum. if this is an older unit this is not uncommon.
1) you can try to replace the seal
2) or you can buy another washer
service repairs for this cost almost as much as a new washer
Aug 10, 2009 | GE WDSR2080D Top Load Washer
My washer has had streaks of grease coming from under the agitator. It is getting on my clothes and I cannot remove it. I took the agitator off and the inside of it is coated with this grease (black,...
GE style washer Common problems: - greeseOil on the clothes or floor. In most cases a new transmission will be required. You can rebuild the Trans for oil on the floor, but I find it best just to replace the transmission with a rebuilt one = less problems and faster repair. I have a parts breakdown of the old style transmission here. How to access the washer information.
Change transmission in GE washer-Take transmission out for repairs. - Unplug washer. Remove agitator from washer by pulling straight up on it, some agitators have a bolt under the cap, remove cap and look for a bolt first. Remove the agitator bearing from transmission hub. Get top up by pressing on 2 clips located about 6 in in from side between top and cabinet. Putty knife or flat blade screwdriver works well here. Take the filter flow tube off. Lift top. Remove three bolts holding basket to hub, and use a 12 POINT 1/2" socket to remove the bolts. Lift basket out of washer. Remove the two clamps holding the black boot to the tub and to the transmission. There are six bolts holding the transmission in the washer. Remove the bolts and lift transmission out of the machine.
To replace bottom seal - Turn trans. upside down in a bucket, put in vice, etc. Remove the nut holding the drive pulley on. Take drive pulley off. You can now pry the oil seal out of the trans. bottom and replace. If you wish to put the proper amount of oil in the trans. you will need to remove the bottom cover. Unless you have lost a great deal of oil, I would bypass this. I would estimate the oil loss and put in a lesser amount through the opening where you will be putting the new seal. When replacing the pulley, do not turn the nut holding pulley on. Hold nut stationary and turn pulley in the direction that nut will tighten. This will keep you from separating the hub, torque spring, and drive collar in the transmission. If you see evidence of water in the transmission, my recommendation would be to purchase a rebuilt transmission and repair in that manner. You may wish to do this regardless of the condition of the trans. You will receive a one year warranty with the rebuilt trans. I have a parts breakdown here for the transmission if you need it.
Usually you have to only add a little oil to replace what was lost...not much...really!!
The oil used is a Non-detergent, Gear oil approximately 90 weight. The main pulley seal is WH8X281 and foam nut seal is part # WH2X671.
Jul 13, 2009 | GE WPRB8050D Top Load Washer
GE WHRE5260E Top Load Washer Logo
684 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
