No sound on LG J10HD Home Theater
Every other thing is working fine. I think it has to do with lock from the remote control.
  • Anonymous Apr 14, 2009
    exacly the same, just bought it, but no sound......
4 Suggested Answers
SOURCE: Sony DVD Home Theater System remote control code
sony dvd surround sound remote codes
Posted on Oct 25, 2008
SOURCE: impossible de sortir le cd audio
try holding down the stop botton down for about 10-15 secs or less it should turn off
Posted on Jan 04, 2009
  • 9 Answers
SOURCE: We have a Panasonic DVD
Try cold start.
Power off main set manually by press power button on main set.
Unplug power cord from main set.
Wait for about 5 sec.
[Without plug in power cord] Press and hold "Power" button without release it.
Plug in power cord (must have power) to main set by using another hand [while another hand still press on main set power button]
Keep holding until u see ------ on main set FL display.
Then release you hand which just now pressed on main set.
Power on main set again by manual press power button on main set.
Result should be OK (unlocked)
Posted on Jan 06, 2009
SOURCE: LG compact home theater system: LFD790, how do I
Hi
Do you have a fix for the same problem on an LG HT321 system anyone ??
Posted on Jul 18, 2010
Tip
LG LH-D6235 Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | Audio Players & Recorders
Tip
Follow these steps:
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
My Comcast remote will control my LG LHB535 receiver/blue-ray player in all respects but the volume. I used code 20591.
You need to change the volume lock for the remote to go to your AV receiver, not the TV. By default all Volume control will go to the TV, but you can change volume lock to go to AV receiver instead. I switched to DirectTv and had to do the same thing, so I may not have the right term used on comcast, but essentially the same thing.
Dec 29, 2010 | LG LHB535 Theater System
Need Remote Code for LG LFD790 Home Theater
I NEED REMOTE CODE FOR LG LFD 790 FROM REMOTE GE
Dec 30, 2008 | LG LFD790 System
Impossible de sortir le cd audio
Nov 12, 2008 | LG Audio Players & Recorders
Sound with television
i have the same problem, has anyone found a solution?
Jul 31, 2008 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Jun 16, 2008 | LG LHT734 System
324 people viewed this question
 Grubhead
Grubhead
