Question about Kitchen Ranges
I HAVE A WOOD PELLET STOVE CAN I USE MY OLD CHEMINY IF I PUT A 3 INCHES STAINLESS STEEL PIPE INSIDE
  • 3 more comments
  • pegodin Sep 28, 2008
    What I meen is if I PUT A 3 INCHES PIPE AS REQUERED FOR THIS TYPE OF STOVES WOULD IT WORK AND WOULD IT BE SAFE .
    Do you have a better solution I'II like to know your way to do it properly.
    thank you
    What do you mean by working flute
    Ihave awood pellet stove that I want to install in my basement to replace my wood stove.
    Can I use my old cheminy and put a 3 inches stainless steal inside as requaered for this type a stove will it work ok and will it be safe.
    THANK YOU
    Could you please be more spacific with your answer .
    Thank you
  • pegodin Sep 29, 2008
    Thank's for the solution
  • 1,800 Answers
Yes if it can reach it place and u feel that its well connected
and that will be safe!!
plz rate this post
Posted on Sep 28, 2008
  • Jalal Sordo
    Jalal Sordo Sep 28, 2008
    yes u can just do it right and be assuer of the connection
    President:
  • 1,263 Answers
Yes you can just as long as you have a working flute for proper venting. please rate.
  • Ronald Mueller
    Ronald Mueller Sep 28, 2008
    by working flute i mean you have to have a way to force the smoke from the stove up the pipe your old chimney at one time had a forced air furnace so no need for a flute with a wood burning stove just like a fire place you have to have a working flute to force the smoke upward so as to avoid carbon monoxide from collecting in the house. please re-rate this solution... thanks
    Genius:
  • 1,550 Answers
Yes you can use old cheminy .
But your statement is little confusing can you repost your problem or queries
SAM ANDERSON
Does anyone have any information on the Pine Ridge 500 wood stove? I'd like to know who the manufacturer is and what the EPA specs are.
PDF]installation and operation manual - Wood Pellet Stoves ...
www.pelletking.com/...stove-manuals/whitfield-advantage-iit-pellet-stove...
Services) and the listing mark is Warnock Hersey. Testing: In accordance ... The assembled pellet stove model Advantage II-T C FS and. Advantage II-T C INS ...
[PDF]INSTRUCTION MANUAL - Ignite Dealer Portal - Regency ...
manuals.regency-fire.com/getattachment/.../R12-R14-R16-Manual.aspx
Tested by Warnock Hersey ... LISTED FACTORY BUILT FIREPLACE ACCESSORY HEARTH STOVE ... it is important that you read this manual throughout.
Nov 01, 2015 | Home
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
What is a 5 u code on a pellet stove
New Stove Auger not moving shows S U in display ' Hearth.com ...
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Nov 25, 2010 - 25 posts - ‎6 authors The letters "S U" mean the stove is in "Start Up mode. ... At this point load the stove w/pellets and hit the start button again. ... Shows SU again and settings are at 5 and 5. still no auger movement, not even the slightest bit. ... The E-0 code is the no error errorcode and stove will enter normal operation which ...
Oct 03, 2015 | Pool & Spa
What is causing the ready light to flash red twice when I try to light my pellet stove
[PDF]INSTALLATION AND OPERATION MANUAL - Wood Pellet...
woodpelletheat.com/WinslowManual.pdf
by P Stoves - ‎Related articles
Please read this entire manual before installation and use of this pellet fuel-burning room .... FLY ASH BUILD-UP: For all wood pellet fuel-burning heaters, the combustion ......Ready Light - lights up when stove is ready to operate. Igniting Light ..
Sep 27, 2015 | Pool & Spa
My stove keeps going out on E2 and shuts down why
The E-2 Error code indicates an automatic shutdown because the stove does not detect a fire. Check out Englander's troubleshooting guide to some of the causes.
http://www.heatredefined.com/faq/troubleshooting-guide/pellet-stove/evolution-pellet-stove/evolution-pellet-troubleshooting-guide/e-codes/e-2-failure-to-start
Feb 27, 2015 | Englander Direct Vent: 2,000 sq.ft. Pellet...
Poor draft on savannah woodstove
Drolets are a real pain at times. Don't buy their pellet stove. Check your stove pipe to insure its clean and not blocked. This includes spark arrestor. Is you stove cap 2' higher than anything 10' away from pipe? Refer to install manual. If you are not getting an y back draft issues with smoke inside house you may need to add on a section of trip wall pipe at the top.
Feb 27, 2014 | Drolet Savannah 55,000 BTU Wood Stove,...
I'm installing a wood stove insert with a 6" flu. Can I use a 5" or 5.5" chimney liner and be ok? Thanks in advance. Jacob Ullucci
If the stove exhaust pipe is 6", you need to have a minimum of 6" all the way up your chimney. If you use a smaller pipe you will limit your flow, which causes excess cooling and crystalizing of smoke creating more creosote, and more of a chance for chimney fire. The perfect solution would be to run a 6" liner down your chimney, and connect it right to the top of your insert. Make sure you install a top plate at the top of the chimney to insure pieces don't fall outside the liner. Lastly install a stainless steel cap to keep any animals out.
Sep 13, 2013 | Hearth Products Controls Round Match Lit...
Quadra Fire Pellet stove-will not ignite
I own a Quadrafire pellet stove. I have had this thing for 10 yrs. It seems every year at the start of the season I have some kind of problem. I clean it at the end of the season completely. First couple of burns are fine then get a good cold day and it doesn't work. All the gaskets, the exhaust blower, ignitor, glass front, and exhaust piping have had to be replaced. Now I have a blinking red light in the control box and cannot find anything on line to help. Does anyone know why this red light blinks 3 times every 10 seconds inside the control box? It's not the call for heat light. Think I may change to a wood burning stove to many headaches.
Oct 20, 2011 | Napoleon Auburn Pellet Stove Heater
I have a wood burning stove fitted in our modern home. The stove has a vertical flue pipe fitted from the top and up through a purpouse built chimney liner in the ceiling. the lower parts of the system...
(1) The lower "enamel" pipe is possibly Ceramic coated pipe, used for high temperature flue applications.
(2) The "stickey black tar" is creasote. Whoever installed the flue pipe did it wrong. It needs to be reversed so that the "Crimped" end of the pipe is pointing down. That way the creasote will drain back into the stove and get burned up.
Apr 01, 2017 | Heating & Cooling
Offset of verticle stove pipe between stoveand chimney
use single wall pipe in the heated area.
Aug 19, 2008 | Grilling
Kitchen Ranges Logo
91 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
