Question about RCA DIRECTV Satellite Remote Control
I HAVE AREMOTE FROM DISH NETWORK THAT WAS MANUFACUFACTURED BY YOUR COMPANY. IT WILL NOT DO ANYTHING. I KEEP CHANGING THE BATTERIES AND IT SAYS LOW BATTERY. NOW I CAN NOT EVEN CHANGE STATIONS. WHAT DO I DO? THANKYOU FOR YOUR HELP!!
  • 374 Answers
Jim,
If the remote keeps draining batteries at an unusual rate, which is what it sounds like you are describing, there is an internal fault in the circuitry of the remote and the remote must be replaced. Once you get the new remote I can help you program it to your receiver and to your tv. It is a fairly simple process but will probablty get lost before you get your new remote if I explain it to you now. Make sure that the remote is the same model type that you have now. The remote model number will be on the back and will be a two digit number e.g. 8.0, 6.3 etc. There are three basic types of remotes: Infra red, UHF, and UHF pro which is an IR/ UHF combo; and you want to ensure you get the proper type. Let me know when you have the new remote so I can get you set up correctly again and I apologize for the inconvenience you have had with this equipment.
Sincerrely,
Jim
Posted on Sep 29, 2008
TV remote won't work after changing batteries
When battery is changed, all the previous settings will be lost from the remote control. You should once again set it to your device, using codes.
Jan 10, 2013 | DISH Network Televison & Video
My dish network remote control powers the receiver (turns it on and off), but it won't change channels or adjust the volume. why?
I hope that your remote is working now, but if it is not, or you have any other issues in the future, here are some steps to help out. The link below will walk you through programming both your remote to the volume and the receiver. Sometimes the remote will not work certain functions if the batteries are starting to ware out, also if there is anything blocking the dish, the remote doesn't work as well. So you will want to make sure that there is nothing in front of the receiver, such as glass, and that your batteries are less than 60 days old.
Steps 1-5 are for the receiver, and 6 on are for the tv! I hope this helps!!! http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
DISH Network Customer Service
Jul 30, 2010 | DISH Network IR Remote Control
Remote won't work
marybsaxton
If changing the batteries did not resolve your issue with your remote, we may need to replace the remote. You might check to see if all batteries have the positive side facing down on the remote. If so, then call 1-800-333-3474, speak with Tech support. I hope this helps.
Ray Calo
DISH Network
Apr 18, 2010 | DISH Network IR Remote Control
My remote show it is supposed to work but when i try to turn on my cable with my dish remote it doesn't do anything
  1. open the door on the right side of your receiver and press 'Sys Info
  2. press record multiple times on your dish remote
  3. press select
  4. if this doesnt work change the batteries and try again
  5. if this doesnt work call Dish for a new remote
Jan 26, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Sounds stop working after about 1 to 2 hours of viewing.
We would be happy to help you with this. The volume levelingfeature that we have sounds perfect for this situation; it keeps the volumelevels consistent between programming and commercials and also prevents drasticvolume level changes when switching between HD and SD programming. The volumeleveling feature is supported by the following receivers: ViP 222k, ViP 612,ViP 722k, and ViP 922; the model number of your receiver is displayed onthe front in the lower left corner. Your receiver needs to be connected by onof the following: composite cable (green, blue, red cables), coax cable (singlecable with metallic tip), HDMI or optical devices that do not support Dolbyaudio.
Start by pressing the menu button on your DISH Network remote control, thenpress the number 6 for system setup then 7 for audio output. Once therehighlight the "Enable" option below Volume Leveling and press select.Once enable exit the menu by selecting done on the right side of the screen.
We hope this helps to get things set up the way you like it. Thanks forchoosing DISH Network!
Phillip Chang
DISH Network Customer Service Representative
Jan 17, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sat button on remote stays lit and it won't let me do anything in just stays lit. I have even changed the batteries
jsblondie316
If the light stays on and you have already replaced the batteries, then the remote needs to be replaced. Please call 1-800-333-3474 and speak with Tech Support. I hope this helps.
Ray Calo
DISH Network
Jan 14, 2010 | DISH Network 142923 Remote Control
All Four Red Lights On, Cannot Use Remote
This is a new one-
I would try removing the batteries and letting it ferment overnight; it sounds like too many other electronic devices that 'hang up.' If you ahve the setup leased, they will send you a replacement and return mailing instructions.
BTW, don't let them bully you into paying anything for . . . anything. If you have been faithful paying them, they have a moral responsibility to keep their junk running. There's always DirecTV, doncha know?
May 15, 2009 | DISH Network IR Remote Control
Dish net 311 no power
Dish Network (Echo Star Communications) is a problem company. The best solution to your problem is to switch to cable or Direct-TV.
Dish Network should be avoided at all costs.
May 06, 2009 | DISH Network 311 DTV Receiver
And if Remote is missing
THERE IS NO OTHER CHOICE YOU HAD TO USE AREMOTE CAUSE SERVICE MENU CAN ONLY SET BY REMOTE OF ITS OWN
Aug 27, 2007 | JVC AV-27230 27" TV
RCA DIRECTV Satellite Remote Control Logo
79 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
