Beer spillage on my macbook pro keyboard and now some of the buttons(including space bar)do not work or responde
    Problem Solver:
  • 10 Answers
Turn off your computer and let it dry out. Leaving the computer running will just cook the liquid and make it stickier. If you ever have a spill again, turn your comp off right away and let it dry out for a good week.
I spilled wine all over an old laptop of mine. Some buttons wouldn't work. I gave it to a friend who asked for it and she says it has worked great for her.
Give your comp a bit of time to dry out. Let it sit in the sun in a window for a week, then try to turn it back on.
If the above doesn't work, ask the guys at your local computer store what you could try to clean it.
Posted on Sep 28, 2008
How do I fix spacebar that is not registering/responding on my keyboard
you find out why its not working
did you spill something on the keypad
other than this is the space bar mounted correctly???
Mar 26, 2015 | Roccat Ryos MK Pro Mechanical Gaming...
Apple MacBook Pro MC723LL/A 15.4-Inch Laptop, three keyboard buttons not working
It sounds like there is debris beneath the keys. I would recommend using a blower to clear it out.
Dec 07, 2013 | Apple MacBook Pro Laptop Computer with...
Macbook pro usb short circuit
Take the phone, computer, and cable to the Genius Bar in your closest Apple Store and ask them to look at it. This is hard to diagnose through text; they will be much better equipped to help you.
Jun 09, 2013 | Apple MacBook Pro Notebook
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
Have a macbook pro and it has locked up, black screen now and isn't responding to mouse or keyboard
This has also happened to my Macbook Pro - nothing would work, so i basically pressed the power button until it closed down and waited a few minutes and turned it back on. The problem ( touch wood) did not come back again yet. Good luck!
May 18, 2011 | Apple MacBook Pro Notebook
Cursor and keys are unresponsive tryed 2 check if it was number lock witch its not
There has been a known issue with the first key (any key) of a Macbook Pro, not responding when typed and Apple appears to have addressed this with this software update for the Macbook and Macbook Pro:
Run the Macbook Pro Software Update v1.1 and the Macbook, Macbook Pro Keyboard Firmware update v 1.0 per this link:
Keyboard Issues with Macbook Pro
Let me know if this helps.
Regards,
-Mactechtrainer
Mar 24, 2010 | Apple MacBook Pro Notebook
Macbook goes to sleep and doesn't wake up unless I do a hard reboot.
I have seen this caused by having a mouse plugged into mine. I have removed the mouse and touch the touchpad and it has come up from sleep.
That very well may not be your problem.
Here is the procedure that is recommend from Apple to help with the not waking from sleep problem. I included both methods as it is not clear which macbook you have. I also included the link to the article at the bottom.
The System Management Controller is an integrated circuit (computer chip) that is on the logic board of the computer. As the name implies, it is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Over time, the settings in the System Management Controller may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, not charging the battery, or not recognizing the AC Adapter, among others.
MacBook (13 inch, Late 2008), MacBook Pro (15-inch, Early 2008), and MacBook Pro (17-inch, Early 2008)
  1. If the computer is on, turn it off.
  2. Disconnect the AC adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
Note: Starting with MacBook Pro (Late 2008) and MacBook (Late 2008) models, you may instead use the reset method for MacBook Air (below) to reset the SMC. All earlier models of MacBook and MacBook Pro must use the method described above, which involves removing the battery.
MacBook Air and MacBook Pro (Late 2008 and later)
  1. If the computer is on, turn it off by choosing Shutdown from the Apple () menu.
  2. Connect the power adapter to a working power source.
  3. On the built-in keyboard, press (left) Shift-Control-Option along with the power button once.
  4. Wait 5 seconds and press the power button to start the computer.
Note: You must use the keys on the left side of the built-in keyboard.
Here is the link to the article at the Apple support site.
http://support.apple.com/kb/HT1411
Aug 28, 2009 | Office Equipment & Supplies
Space bar, left-side enter key and backspace do not respond.
Try buying a can of compressed air and cleaning around those areas if you have spilled liquid on them ,that could be the prob as well
Jul 21, 2009 | Logitech S 510 (967555) (DH967555)...
The space bar on my new MacBook Pro often sticks so there are no spaces between words. MacMall had me do something in the system folder on the keyboard - worked for about 15 minutes. AppleCare had me take...
Go to your local apple store. Set an appointment with the genius bar.
Tell them you want a replacement for your laptop.
If you're firm about it... but be nice, alot of times apple will replace your unit... Tell them about all your attempts, and failed solutions.
They usually will make good on this type of thing.
Let me know how you do.
Mar 14, 2009 | Apple MacBook Pro Laptop Computer with...
Spacebar does not work.
sounds like the rubber is stuck, take off your space bar (make sure you can put it back), make sure theres nothing on the little rubber peices, and put it back on
Jul 25, 2006 | Apple MacBook Pro PC Notebook
Computers & Internet Logo
David Payne
David Payne
