Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water leaking out onto floor
I have a wirlpool model #et1lfkxkq01. it keeps leaking water to bottom of fridge and out to floor. iwould think it is a drain stopped up but i have no idea how to access it to try and clean it. if im wrong please help me with suggestions or maybe a diagram. thanks scott
  • 24 Answers
Scott you are dead right with the drain. If you open the freezer door and look inside at the back in the middle of the plate at the back on the very bottom there is a small hole. This hole goes all the way down through the fridge and then finally to a dish that sits ontop of the compressor via a hose. If any part of this hose is blocked then it will find an easier path which is uually out the front and on the floor. The most likely culprit would be ice. Leave it off for a half a day or so so the ice melts then turn it back on and test it for a week. Do not turn the thermostat up very high otherwise the problem will reoccur.I hope this helps.
Posted on Oct 08, 2008
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Water leaking bottom of crisper.
You may just have to manually defrost it.
Dec 16, 2014 | Fisher Refrigerators
Ice build u p and leakage in freezer
you have a blocked drain in the freezer,when the machine goes into defrost the heater comes on and melts the frost off of the evaporator coil,the water melts and goes down the drain hose under the coil and leaks down to a drip pan near the compressor where it evaporates from the heat,your drain is blocked and the water is leaking onto the freezer floor and will drip out onto the floor,i use a steemer to blow out the drain line,shut down the machine or unplug it,melt out all the ice with hair dryer,depending on your model you might have to remove the back inside wall of the freezer to get at drain hole,you need something to push the **** out the drain hose,you can try a turkey baster or air from a compressor or a shop vac set it to blow,when you think it's clear pour a cup of hot water into the drain,if it drains down you're done if not keep hitting it with heat and air to push it through.
Sep 01, 2012 | Refrigerators
Fridge freezer leaks water from bottom
your drain for your evap is clogged...... need to clear drain of ice then will be ok. brand and model # would be helpful.
Jan 03, 2012 | Refrigerators
A small amount of water is leaking out of the front of the refrigerator onto the floor every day and I can not fine the source of the water. Is there a drain pan and if so where is it? If it is not the...
older fridges drained water into a pan with the compressor in it, thus cooling the compressor and evaporating the water, this is located at the bottom back of the fridge. if this fridge has a water and/or ice dispensor, the water could be leaking from many a place.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Model # TBX18TRBR large puddling leak on floor, think has to do with defroster messing up?? A GE refrigator serial # HG539639
I've got the same fridge with the same problem (believe it or not it was manufactured in 1992 so it's a wonder it's still working).
I also have been able to narrow the problem down to a defrost issue. It appears as the coils are defrosted, the leaking water drains down through the inside of the fridge, pools in the bottom of the fridge (under the bottom drawers), then when that area is full it runs out onto the floor.
I'm still troubleshooting and will post back here within a week with my results.
Aug 22, 2009 | GE Refrigerators
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
99 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
