Question about Kinyo SA-626 Computer Speakers
No sound to speakers
Plug speakers up to pc Kiinyo Zone 2.0 Amplified Speaker System
    Problem Solver:
  • 14 Answers
Hallo,
I need more details:
1. The driver is installed on the computer and is it something singing?
2. some sound card you have to configure them how you want and have a software or a menu for configuration in which to choose which output for what to connect to it. need the sound card name.
3. The system is plug in?
Hope to help you after I have this answers, have a nice day
Posted on Sep 28, 2008
Is there anyway to get an amplified signal to my zone two speakers without an additional amplifier? Should I be using the Speaker "B" outputs?
Check your speaker setup menu to make sure that zone 2 is enabled. Also, a lot of receivers only allow analog inputs to be used for zone 2, so if you are using something like hdmi, or optical than this might be the problem.
Jul 27, 2016 | NAD T754 Receiver
Zone 2 does not respond
Make sure that you go into the speaker system menu and set it to zone 2. The zone 2 speaker jacks can be assigned to other things such as surround back.
Mar 28, 2013 | Denon AVR-2106 Receiver
Our 2nd zone won't work, we get the error saying check SP wires. The wires seem connected correctly. We also can't change the volume on zone 2. The Yamaha unit is working otherwise.
U cant get an amplified out put form ur av receiver for zone 2. speaker a A and B is the same out put of frond left and right. it is not ZONE 2 output. U can get only a pre output for zone to from this receiver. U nee a separate stereo amplifier for using zone 2 .put an amplifier in the other room, connect the zone 2 pre out to it. And do the following setup in ur av receiver .
The receiver shows check speaker cable because its amplifier minimum impedance is 8 ohms . when u connect other speaker in speaker the total impedance will come under 4 ohms. Speaker b is not ZONE 2 in this amplifier
1. press the input selector button A or B to select the source component you want to setup.
2. press and hold LEARN (on remote) button about 3 seconds by using a boll pen or similar object ( SETUP and the selected component name appear alternately in the display window.)
3. press up or down arrow to select "zone2"
4. press LEARN to complete the Zone 2 setup.
5. press source select up arrow to display Zone2 in the window.
6. press an input selector button to select input source u want to listen to in the second room
7. u can control the component by using the component control area button
ok
Dec 26, 2010 | Yamaha RX-V2200 Receiver
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Feb 02, 2010 | Yamaha HTR-5890 Receiver
Plug in external speakers w/ volume very low in HP2009m screen
check if the external speakers u plugged in came with an internal amplifier, if not then u will have to use an external amplifier to get max output from your external speakers.
Sep 02, 2009 | Audio Players & Recorders
No sound from external speakers system
Look into your monitor settings and computer settings and see if you can reverse the "input" and "output". If both are set to line in or line out then they pretty much cancell themselves out.
May 23, 2009 | Televison & Video
Just need to know how to hook up proper for stereo sound
start with the right speaker, that is you control for now. plug in the power supply one end to the wall the other to the right speaker, connect the left and right speakers, connect the sub woofer to the right speaker, (most of the plug and sockets are color coded, or at least different sockets sizes so they will only fit properly with the correct connector) now you should have one wire left coming out of the right speaker-that gets connected into the GREEN socket of you computer.
Now you should get sound...good it works.
From here we go to START->SETTINGS->CONTROL PANEL->RIGHT CLICK ON SOUND AND AUDIO DEVICES->VOLUME TAB->ADVANCE (TO THE RIGHT OF SPEAKER VOLUME->SPEAKER SETUP->FOR THE DROP DOWN ARROW SELECT DESKTOP STEREO SPEAKER->APPLY->OK
And that my friend is properly done.
enjoy,,, please leave a rating, thank you
May 10, 2009 | Computers & Internet
Trying to hook up aftermarket radio 98 windstar limited.
If this model has an amplified system, then you may need a different wiring harness. The harness you purchased may be for the non amplified model. Try that, and let us know.
Jan 29, 2009 | Metra Ford Premium Sound System Amplifier...
Kinyo SA-626 Computer Speakers Logo
75 people viewed this question
Top Kinyo Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Lawrence Oravetz
Are you a Kinyo Audio Player and Recorder Expert? Answer questions, earn points and help others
