Lavazza Espresso Point Capsule Machine - EssentialEspresso.com
Problem for Lavazza Espresso Point Capsule Machine -...
Lavazza Espresso Point Fuse Location
By coffeefan on Sep 28, 2008
I have a dead machine and was told it is the fuse but I can not find it anywhere in the machine. Can anyone help?
Comments:
Sep 28, 2008
- So if I trace the cable back to the power supply I should find an inline fuse somewhere near the end but in the cable itself. Is that correct?
Same Problem
Mar 16, 2009
-   I have the same problem, but don't understand the proposed solutions. Is the fuse in the wire or in the body of the machine? If it is in the "black" part, that is, the receptacle for the power input, how does one pull that out (is it simply pulling, or must one take out the back cover of the machine, or is there some kind of a mechanism that holds the receptacle in place?) Ez -   ezios
Mar 16, 2009
-   dfgsdfg -   Guest
Solution #1
posted on Oct 07, 2008
Not Rated)
altierit
Rank: Apprentice
Rating: 0%, 0 votes
if you go to the plug and the machine meet. pull out the plug and attached to the machine (where the plug goes into) if you pull this black out of the machine. Located in there are two small fuses', looking at them you will noticed if they are burned out or not. Pick up new ones at home depot.
Was this helpful?
Yes
No
Solution #2
posted on Sep 28, 2008
Not Rated)
guillocapo
Rank: Apprentice
Rating: 100%, 1 votes
seguí el cable del enchufe. Si no encontras el fusible, podés encontrar un cartucho plástico a lo largo de uno de los cables, esto es un fusible aéreo y si lo abris te vas a encontrar con el fusible.
Comments:
Sep 29, 2008
- Yes, it's correct. These is a air fuse (fusible aereo)
Open these like a shell and in there is a fuse.
Good luck
Was this helpful?
Yes
No
Popular Solutions for Lavazza Espresso Point Capsule
Questions and Unsolved Problems for Lavazza Espresso Point Capsule
Do you recommend Lavazza Espresso Point Capsule Machine - EssentialEspresso.com?
Answer
Answer
our machine is not dripping the coffee into the cup but is dripping water into the basket and is... (More)
Answer
the red light next to the bulb is on steady but the red light next to the coffee cup with an... (More)
Answer
machine will not turn on. While steaming milk, I presses the steam button again (I meant to press... (More)
Answer
When the machine is on and the coffee is making, not all of the water goes through the pod and I... (More)
Answer
could I have problems with the caps in my mouth in years to come?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Lavazza Espresso Point Capsule...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
