Connector pulled off power buton wires
I am installing new motherboard connector came off 5 wires 3 for light 2 for power button i need to knowwitch way wires go.red,green,and black to light blue and white to power button i am not sure witch way the go on new motherboard
  • Daniel Adamski
    Daniel Adamski Sep 29, 2008
  • Anonymous Jan 29, 2009
    the mother bored pluges are not labled
    President:
  • 2,351 Answers
Hi ford, the most common case colored wires used for negative - is white. The colors blue, red, green are usually positive +. The internal speaker though it uses a 4 pin connector only plugs onto the 2 end pins. Black is connected to negative - pin & red is connected to + positive pin. (Depending on the MB model).
All these case LED's use 5volts DC. If you make a boo-boo, don't freak out. You can usually shut down the system & turn the connector 180 & re-connect it with out hurting the board. Suggest you connect 1 at a time & check in-between each.
Still having trouble, include the name & model number of the MB.
Mike
Posted on Sep 29, 2008
Casio xj-s41 lamp and temp light amber blinking
FIRST LOCALIZE THE UP/ DOWN/ LEFT/ RIGHT AND MIDLE BUTON- ON FUNCTION CONTROL
OK...
KEEP PRESSD FOR 10 SEC
INPUT / MIDLE BUTTON FROM FUNCTIONS/ AND RIGHT ARROW
RELEASE THOSE BUTTONS
NOW YOU SHULD GET THE ERROR RESETED.
NOW YOU HAVE TO INITIALIZE THE UNIT:
POWER OFF UNIT( FROM POWER BUTTON)
POWER ON
PRESS AGAIN: INPUT/ MIDLE BUTON/ RIGHT AROW TILL SHOWS A SERVICE MENU ON SCREEN
CHOSE INITIALIZING AND RESEAT UNIT.
GOOD LUCK...GO CANUCKS
Nov 30, 2010 | Casio XJ-S41 SuperSlim DataProjector ...
Installed gigabit MB new power supply, all new parts and only get flashing lights on the optical drive on boot up any ideas what i could be doing wrong ?
1. Check whether two power connectors are connected (one is 20 pin and the other 4 pin)
2. Remove all FRONT USB, Audio, HDD, CDRom and other connections on motherboard, except the power button connection now turn on.
3. If still does not, instead of Power button use reset button connection for Power button and try.
4. Check whether proper memory supporting type is installed in proper direction, try putting in another slot.
5. Change the SMPS eventhough it may be powering on.
6. Check the Motherboard by keeping it externally taking precautions.
Sep 11, 2010 | Intel Motherboard
My Ibm is T30 the when i put jack power the indicators of charge batere is on. But when I'm push the power button is doesn't work then indicator light still off. Whwn I push then power button and I put...
Hello there:
here are the hints or ideas
1) You may have a bad or damage, power on connector (soldering) inside the motherboard.
2) Bad Charger , you need to check these with a multimeter, if you know how to do it.
3) bad video inverter or its starting to fail.
4) or simply your video card, is failing. perhaps dust, or the fan for the video card is bad or clog .
Good Luck
Carl
Apr 21, 2017 | IBM Thinkpad T30 Notebook
Configuration
Hi
The wires that read +5 -d +d and ground those are USB connectors each usb connector will have 4 wires, +5 -d +d and ground so that goes to usb pins.
The sw must be power switch
The HDD led is the load light
Reset is the reset button
Power led is the front power light
SPK is the speaker / beeper.
Can you tell me the brand and model of the motherboard? They are documented in the user manual. but generally in the bottom right corner of the motherboard you have the connectors for the leds and buttons, its all written into the motherboard with small white text. but I can get clear instructions from the user manual for you.
You can look for the motherboard details between the expansion slots and between the cpu and memory.
Thanks,
Ekse
Feb 03, 2009 | Intel SVM266A VIAP4M266A (SYNTAX SVM266A...
Front panel connections
Hi sjcrofts,
The most common problem for most people is knowing what wire color is positive & which wire color is negative. The colors blue, red, green, light blue, light red & light green are normally positive. The color white & black are negative. Your board uses only 2-pin connectors. The 3-pin power connector can be turned into a 2-pin connector to work with the M848ALU pins.
(Page 13, PANEL1). How to? Take the three pin connector, on the back side of the connector you'll see a small tab that holds the wire into the connector. Use a needle & pull tab up while pulling the wire out at the same time. The wire should slide out. Insert the wire back into the connector next to the other wire. You do not need to hook up the SUS led which stands for suspend.
Pin 1 is positive & the manual shows this by adding the _P = positive.
Pin 3 which is to the right of pin 1, is negative for the hard drive led. Pins 9 & 10 are not used.
Good luck sjcrofts!
Mike
Nov 30, 2008 | PC Chips M848ALU Motherboard
Need help
the pin arrangement is 4 pins and pins.
From left top row (4 pins) first 2 are power led, next 2 are power switch, next 1 is empty
from left bottom row ( 5 pins ) first 2 are hdd, next 2 are reset, next 1 is empty.
The connectors for the power led and the hdd produce a light, if they don't produce a light, power off your pc and switch the cables round the other way and power on again.
Oct 30, 2008 | E-Machines (308714) Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
No boot or wake up
Chances are you need to change the power supply,, but first you need to check to see if its workingm this is quite easy
1.) unplug it
2.) remove the power connector from the main board
3.) on the power connector is a green wire(ONLY ONE) and right next to it is a blact wire(any black will work)
4.) use a peper clip or unisulated wire to bridge the green and black wire by inserting it into the jack contacts.
5.) plug in the power supply, if the fans spins then its working..
If the power supply is fine then you will need to check the power button connectors *wire from power button that connects to the main board),, if the connection is fine, then unjack the connectors and use a bladed screwdriver to bridge the pins for the power button connector on the main board,it should boot up. If not then you need to have that mainboard replaced
Jul 27, 2008 | EliteGroup P4M800-M7 Motherboard
Power for HP554e
I will try to help you. Locate a 10-pin connector below your backup battery. This connector has only 9 pins. It has four pins on the top and 5 pins on the bottom. Connect connector from your power button to the top row pins 6 and 8. Look at the diagram below I marked connection points with the “+” sign.
2 4 6 8
0 0 + +
0 0 0 0 0
1 3 5 7 9
Just for your references. Pins 2-4 for Power LED, 1-3 for Hard Drive LED, 5-7 for Reset Button.
Regards
May 23, 2008 | Cornerstone FIC AM37-L Socket A XP...
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
Computers & Internet Logo
443 people viewed this question
David Payne
David Payne
