Question about Whirlpool Duet GHW9150P Front Load Washer
F 22 front door locked and door won't open.
I put in a regular size load and started the washer. Seconds later the F22 code came up. I did what the trouble-shooting section suggested, but it didn't work. The door just won't open now. I tried the door lock and unlock and when I try to start it, it just beeps three times. HELP?
  • mtrman34 Sep 29, 2008
    I have the same problem but no code..Door locked & nothing happening..
    Sergeant:
  • 409 Answers
the F22 stands for the CCU/Touchpad error. in other words, the keypad has lost connection with the control board behind it.
this is what you do:
unplug the washer
take off the console
check the connection between the touch pad and the CCU boad
make sure that nothing looks corroded or burnt
make sure that nothing is pinched or bent
unplug and replug wiring harness and connections form keypad to the CCU board
let me know if it this works.
Posted on Sep 30, 2008
F22 error (in any washer setting) will not start, and cannot get door open. What "electrical "problem is this? Also, how do I get my clothes out short of using a crow bar on the front door!
F 22 is door lock error most likely need door lock but check door strike on door..To get clothes out remove lower kick panal reach up inside washer //at the bottom of door latch there is a small round tab pull down on it to release door..while you have the kick panal of there is a tech sheet inside washer try putting in die test/////but I would say door lock..Hope this helped If it did please vote...If you need more help please ask...Good luck
Feb 02, 2011 | Kenmore HE2 Plus Front Load Washer
Door will not open has a code 22
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer door is locked and won't open. Error code
DOOR LOCK ERROR
After 6 failed attempts to lock the door.
Possible Causes/Procedure
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Jan 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F22, washer is locked and will not unlock
IT is a defective lock, unplug the machine for 30 minutes and plug it back in. Then once the door opens replace the door lock and all should be well
Apr 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cannot get washer door to open.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F 22
f22 is dool lock failure depending on you level of mechcanical ability disconnect power remove wire spring from around door seal pull seal away from front remove 3 t20 screws from front panel that hold swt pull swt through opening of seal remove 3 electrcal connections reverse procedure to install
Dec 11, 2008 | Kenmore Elite 45986 Front Load Washer
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
317 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
