Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Kitchenaid mixer leaking oil
I recently found our Kitchenaid K5SS Mixer laying on its side with over a tablespoon of lubricating oil polled beside it. Is there a way of replacing this oil without total dismantle? Will the loss of this oil be harmful to the motor if not replaced? Thanks for any help!
  • tntcrone May 11, 2010
    Do not dismantle until you are sure about what you are doing. It is possible that the oil encased a coil and opening the coil and releasing the remaining oil spells major repair.
  • 135 Answers
Some of the oil has separated from the grease inside the transmission, the grease should be replaced. You don't need a total dismantle,. simply remove the top cover and the transmission housing. Remove as much old grease as you can, then replace it with grease from Kitchenaid Parts, or locate a Shell Oil distributor in your area, you want Shell Darina XL EP-2. The oil that came out of your unit probably won't be enough to do immediate damage, but because it's separating, it's becoming less effective. It'a messy job to remove it but will add years of life to your mixer. If you find this solution helpful, please rate it. Good luck. ricardok45
Posted on Jan 05, 2009
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
How do I replace the oil that came out when the mixer was stored on its side?
Mary Ann,
There actually is not actual oil inside the mixer. There is however GREASE. When the grease gets old it can begin to separate and then leak out like oil. The grease needs to be replaced in the mixer. You can find online video's on how to that and where to get replacement grease.
Oct 22, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Trying to determine how to lubricate the gears?
Hi CONTACT_TOS. I’m not sure what removable cap you are referring to, unless you are referring to the two plastic caps with screwdriver indents on opposites sides of the head? Do not remove them. Those are Brush Holder Caps for access to the electric motor brushes. You do not want to remove them unless you are replacing the brushes.
Why do you want to add lubrication to your mixer? The internal gears of your mixer are factory packed with enough grease to last a 'lifetime'. Unless your mixer is quite old; greater than 10 years, you shouldn’t have to replace any transmission lubricant. Your mixer’s transmission lubricant (grease) does break down over time and usage into its components; basically oil and suspension additives, and sometimes your mixer might leak a little oil that has seeped beyond the transmission gasket and found its way out of the mixer. Gravity can be very insidious. But even then, if the amount of oil you find leaking is small and your mixer seems to be operating normally, you needn’t worry about the replacing the lost lubricant.
If you still wish to check or replace the lubricant, that’s OK, too. It never hurts to get under the ‘hood’ of your mixer and see how it all works. Before you get started though, it would be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and select “Consumer” for User Type, then enter the 6 character Model Number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4). (Check to verify this matches your mixer model.)
Turn to pages 4 & 5 titled: “Case, Gearing & Planetary Unit,” for the disassembly, troubleshooting, and reassembly of your mixer’s transmission gears, along with all the parts. It can get quite messy but be gratifying to diagnose and repair your mixer yourself.
Once apart you can check for any unseemly wear and tear on the gears, etc. You may also want to consider replacing all the grease, particularly if debris is suspended in it.
Besides any replacement grease you might consider replacing the gasket (Illus. No. 26), too. I recommend using a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer along with replacing the lubricant if you wish to.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it. – hslincoln
May 04, 2010 | KitchenAid K5SS Heavy Duty Commercial...
My kitchenaid mixer was stored on its side and leaked oil. I don't dare use it now. Can I replace the oil myself? There are no mixer repair centers anywhere near me.
your oil leaking is cause by a bad gasket or the gasket isn't seated properly. you can purchase this gasket but replacing it does require knowledge of the unit. part number for the gasket is 4162324. the grease can be purchased locally at any car parts dealer. generally a thicker paste type grease is used inside these units, but the original part number for the grease is 4160588 and comes in a container with enough grease for 5-8 mixers.hope this helps
Thanks
Oct 06, 2009 | KitchenAid K5SS Heavy Duty Commercial...
My stand mixer was stored on its side and leaked oil.
Called the Kitchenaid toll free number and found a local authorized repair center. Not a fixya solution, but at least a solution.
Oct 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Oil leakage during move KA KSM90BU
no, mixer is fine. clean with damp cloth and use it. The gears are lubricated with grease and the oil is a little residue from this. Alls well.
Sep 15, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid Mixer leaking oil
Hi Tim. Don't try to pour anything into the side openings, these openings are for the electrical brushes. You didn't state what model you have so my help is limited. Goto www.kitchenaid.com and click on the customer care tab. Enter your mixer's model# into the search window. Look for a parts catalog for your mixer. If there is one, download it.
Your mixer uses grease to lubricate it. If it's leaking oil, the oil and old grease must be removed and replaced. Chevron FM ALC EP-2 is a "Food Grade" grease, use it to replace the old stuff. The transmission housing and Planetary assembly will have to be removed to accomplish this. It's a messy, but necessary task. Once completed, run the mixer for a few minutes each week to keep the oil suspended in the grease, this will extend the life of the new lube. Good luck!
If this solution has assisted you please rate it. ricardok45.
Mar 28, 2009 | KitchenAid Food Mixers
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
Oil leaked from housing
my ultra power ksm90gr 300 watt mixer leaked oil when in the upright position overnight. whats that all about?
Nov 10, 2008 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
377 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
