Question about Sylvania 6427TE 27" TV
Once i turn it on once the fuse blows
Sylvania Color TV 6427ctc blows fuse
    Scholar:
  • 51 Answers
Unless you're a technician, you'll need to take it in for repair. There's nothing a layman can do if a new fuse blows also.
Posted on Jan 02, 2009
Won't turn ON. Found F601 fuse blown on power supply/inverter board. What's the most likely culprit?
Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2
www.shopjimmy.com/emerson-a17f1mpw-power-supply-co...
ShopJimmy
$19.94 - ‎In stock
This Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2 ... board. If the TVhas no power it is most likely because of a blown fuse and failure of other preceding components. ... I tested F601, Q600, R602, 608 and 611, and found them to be bad. ...Power Supply / Inverter Board - Joseph A. on March 4th, 2015.
Common TV Repair for Emerson, Sylvania, Philips ...
? 5:35
https://www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
... LCD TV repairs for Emerson, Sylvania, Philips, Magnavox,blowing fuses "no power" i recommend a TV service LCD repair kit at ... powersupply power-supply "power supply" powerboard "power board" part2 part 2 pt2 ...
What Causes a Blown Fuse in TV Sylvania LCD - YouTube
? 15:31
https://www.youtube.com/watch?v=4P_0aLDZgBY
Jan 01, 2016 | Televison & Video
Dropped tv
first check if there was no short cicuit inside or any wire or parts that have contact and can cause also a grounded and make your fuse always blown...
let me know
Jul 25, 2008 | Sylvania 6615LCT 15 in. EDTV-Ready LCD...
Sylvania lcd tv
If a fuse should blow up, there should be a reason for it. If you replace the fuse without rectifying the problem and switch it ON, the newly replaced fuse too will blow up. Before replacing an other fuse, find out the reason and rectify it. There should be some shorted component/s at its main power supply board. Check and replace them. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ It has schematic diagram of power supply section to many televisions. Pull up older posts by its left side bar. Problems to Sylvania too will be there.
Jun 14, 2013 | Sylvania Televison & Video
My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
Tv blowing fuses
More likely to be either shorted out bridge rectifier or MOSFET in the primary circuits of the power supply. You need to Ohm out those parts.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sylvania+LC320SS8+
Dec 22, 2009 | Sylvania LC320SS8 32 in. LCD Television
Sylvania lcd color tv
if you have replaced the fuse already then you know how to open the back of the set . The problem is more than likely one of the diodes in the rectifer circuit . They will be the four large black components The bad one will have to be desoldered and a new one soldered in its place . It will take a small amount of technicial ability but can be done easily at home.
Mar 25, 2008 | Sylvania LC320SS8 32 in. LCD Television
Sylvania 6632 LG blows fuse when plugged in
I too had this problem. I read some posts on this site about how to repair it, and low behold, they worked! I took the back off of the TV, and the first thing I found was the fuse was blown. With my meter, I checked the first 1N5406 rectifier diode after the fuse, and found that it had shorted out. Then I had to learn to desolder the diode, which I learned about on Youtube. I bought a pair replacement diodes at Radioshack for $1.49 and four replacement 125 volt 4 amp fuses. The whole repair cost about $5.00 and a few hours about learning about electronics. The TV works great! Good times!
Jan 24, 2008 | Sylvania 6632LG 32 in. LCD HDTV
try a diffenrt outlet if it still bunrs of a different fuse! could be the fuse not big enough for the different appliance on the circuit !
i would suggest take it to a tech it could be a problem in the tv that could cost only a few $ to fix !!!!
against trying to much to plug it in and out you could burn transistors or other expensive part of the tv!
Jan 14, 2008 | Sylvania 6632LG 32 in. LCD HDTV
The tv keeps blowing fuses
Hi your problem is that a component(s) inside your TV has probably short circuited to Earth, this then causes a massive current to flow and this blows the fuse. Due to the types of Component failure from this, this TV should go to a reputable repair shop. Get a firm "Quote" and an explanation of what needs to be done.
Aug 14, 2007 | Sylvania 6432GG 32" TV
Sylvania 6427TE 27" TV Logo
158 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
