Cars & Trucks Logo
Anonymous Posted on Nov 21, 2011
Can anybody tell me how to change fuel injectors on 1989 audi 200 quattro?
5 cyl 10 valve engine
Jonah Oneal
Level 3:
  • Audi Master 14,092 Answers
  • Posted on Nov 21, 2011
Jonah Oneal
Audi Master
Level 3:
Answers
14092
Questions
0
Helped
7236489
Points
44533
First relief fuel pressure before disconnecting fuel lines remove fuel pump fuse or relay start engine let it idle until stall out lack fuel fuel now fuel pressure is reliefed. you have to remove top upper air cleaner housing, you have to remove whole entire air cleaning system because the fuel lines with fuel injectors is under the air cleaner filament you have to remove entire fuel line with fuel injector in order to replace fuel injector.
Floods out within 20 minutes after warming up, 1984 4x4 quatro 5 cyl, 2.2 L
Sounds like engine coolant sensor is at falt. If it thinks the weather is below O let's say. It will tell the computer that info and the computer will make the injectors poor the fuel to keep the engine running in the first start up but after the engine is warm and the coolant season doesn't tell the computer any different it will continue to poor the fuel in and will flood the engine. Get them Checked
I have a 1989 audi quatro 200 with an irratic idle problem. the car idles rough till it warms up and then it gets a little better but still not good. then if the engine is warm and you shut it off the car...
first thing to do is check the basics 1 air leaks ie, vacuum hoses 2nd clean the throttle butterfly/housing 3rd the engine coolant temp sensor in the cyl head/ thermostat housing if thats gone out of spec it will not fuel the engine correctly
3helpful
P0303 and P1300 together (Cyl. 3 Misfire)
CODE P1300 IS MISFIRE DETECTED FUEL PROBLEM. WHICH MEAN 3 FUEL INJECTOR IS CLOGGED UP.HAVE FUEL INJECTORS CLEAN AND CHANGE FUEL FILTER.
My 89 audi w\turbo runs great for 4-5 miles,then
1989?? have a funny feeling it could be either crank sensor or the ignition module ,pretty basic vehicle electrics in them days
2answers
Have a 1999 Audi A6 quattro, changed the fuel filter and bled the line. Car won't start. Has fuel all the way up to the rails. Is there a fuel pressure release/switch that is on the injector rails?
did you plug in the fuel pump at the fuel pump. did you cycle the key off and on at least 5 times check the plug at the fuel pump first to see if its still plugged in
Injectors are cracking the ceramic tops
These are hitachi injectors and are horribly engineered..Replace them with modern bosch injectors:
http://www.034motorsport.com/product_info.php?cPath=24&products_id=329
1helpful
1989 audi 200 low gas mileage at 10 mph
Just a silly question...how much driving do you do that is at 10mph? Most times this is less than 5%...so if everything else is fine why be concerned? As far as the why of it, you could have a slight vacuum leak or any number of sensors that are very slightly out of range, not enough to cause a problem, but enough to change mileage expectations. The addition of ethanol to our fuel has also impacted fuel mileage...The dirty little secret about any alcohol fuel is that nearly twice the amount of alcohol is necessary in order to produce the same energy output of gasoline...which will definitely lower mileage. Some power can be "recovered" by increasing compression ratios and changing engine timing (advance)...However today's vehicles are calibrated and built to burn gasoline and cannot without, major mods, be made to use anything but. Alternative fueled vehicles make a compromise in these areas but a compromise is just that.
Car won't start without adding gas to air intake then won't idle
Check the fuel filter, you may have clogged it when you filled the tank.
1helpful
2answers
Ok i have a 1990 audi 200 quattro its a 2.2l inline 5 turbo im having a problem its not accelerating right its sputters a bit and the turbo doesnt kick in it just makes this blowing noise what cani do
Hello, I used to own a 1989 audi 200 turbo. These cars have a rather complicated fuel injection system called constant injection system (CIS 2). They can be difficult for most mechanics to figure out, unless they are already familiar with it. If you do bring it to a mechanic, try to find one that is familiar with these cars. And don't be afraid to get a second opinion. I had one mechanic claim that my car needed several thousand dollars worth of parts, another was able to fix it for under a hundred. The only suggestion I have is that it sounds like it is vacuum related. Good luck!
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Audi Expert? Answer questions, earn points and help others
