CD/Rom external drive door will not open. How can I fix it?
  • 5,568 Answers
If you examine the face of the tray, you should find a very small hole, about the exact diameter of a standard paper clip. (See where this is going? ;-) )
Some need to have the clip unfolded twice since the manual release is pretty far inside and you may have to blindly poke around (try straight in first, of course) before you find the right spot. Once you find it, it will require a good push to get the tray lip to come out.
I have two that do this and am too lazy to take them out and correct the problem since they do sometimes come out on their own. The weak point is kind of a clutch that is supposed to slip if something is blocking its movement and unfortunately, probably because of dust, they lose their grip and slip when they shouldn't.
Posted on Sep 28, 2008
My satellite won't recognize a cd/dvd drive when I open up my computer there isn't a drive at all how can I fix this
If you don't have a cd/dvd rom drive installed on your laptop then of course your laptop would not reconize a cd/dvd rom. Is you laptop a Netbook, usually netbook does not come with a cd/dvd drive. To solve this case, you will need to buy an external cd/dvd drive and hook it up via USB.
Jan 18, 2011 | Computers & Internet
I have a gateway kav60,it does'nt have a cd rom or a floppy drive, how can fix a problem take's a disc. it say's it has a bad file or missing some files.
You will have to get an external CD ROM or floppy drive to plug into your USB port. Most electronic stores will have the CD ROM drive and Best Buy can order the external floppy if they don't have one in stock.
Sep 12, 2010 | Computers & Internet
The CD rom tray will not open.
just watch carefully on cd drive front there is a tine hole somewhere below the door area . now u need a very thin rod or something to insert in to it. there is a button inside that hole so while pressing that button press the eject button. hopefully ur cd drive door will open
Apr 20, 2010 | IBM -3509707 External 4x CD-ROM Drive
Computer will not recognize external cd rom drive
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
If it fails, there is a manual method to edit the registry. Let me know so that I can follow up further.
Mar 11, 2010 | Toshiba (PA3438U-1CD2) CD-RW/DVD-ROM...
I have a Generic External CD Rom Drive and Vista
Can you boot from this external drive maybe you need to set some bios options.
May 04, 2009 | Computers & Internet
Cd rom drive door
Best guess is that a small plastic catch broke. My cousin has similar doors on his CD trays. I personally would take the doors off. As far as repair, again best guess without seeing it, is that you'll need a new door panel.
Feb 20, 2009 | HP GX613AA Pavilion A6300F Desktop PC
Why can I open my EXTERNAL CD PLAYER with Itunes?
i insert a cd into my labtop but i doesn't show on my itunes? HELP!!!
Nov 20, 2008 | Gateway (5501671) External 24x CD-ROM...
How to convert ibm external cd rom drive to dvd rom drive
the only way to do this is to replace the cd drive with a dvd drive in the external case. Should be easy but probably cheaper to buy new external dvd drive.
Sep 27, 2008 | IBM -3509707 External 4x CD-ROM Drive
The cd-rom door not open
Sir,
You have encountered a problem often seeen in LG models. It could have spontaneously generated or as a sideeffect of recent servicing. It is difficult to correct. so an alternative way is use a pin to force open the door.
On the front panel there will be a small mm hole through which insert a straightened paper slip to force eject the door. once door is out a little. pull it or use button to fully take out the tray.
For future, always keep a cd rom inside. that will probably let you eject the tray automatically. Problem occurs usually only withthe empty tray. good luck
Dec 04, 2007 | LG (CRD-8400CB) CD-ROM Drive
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
