Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 The words on the screen on the front of my printer has shifted to the left. In stead of showing - - Copies <1> I can only see s<1> So I cant read what all my options are. Also, it takes over 1 minute, almost 2, from the time I click PRINT till the printer actually starts printing.
    Problem Solver:
  • 5 Answers
Hi zandlishop ,
The best way you can do is to - power cycle the printer- unplugging the power brick at the back of the printer and leave it for about 30 sec. then plug it back in.
-If still has the same problem -
-Search for the menu on the printer to reset to factory defaults
-It should work-
-If still has the same problem call tech support @ lexmark to update the firmware
-hope this can help you,
jim
Posted on Sep 29, 2008
THE TIME IS WRONG ON X5470
To change or set the time on your Lexmark X5470 printer, please follow the steps below:
  1. On your printer operator panel, while on Copy mode, press the Menu button.
  2. Use the left/right arrow button, select Tools.
  3. Use the left/right arrow button, select Device Setup.
  4. Use the left/right arrow button, select Date/Time and configure the time.
I hope this information has been helpful.
Oct 05, 2011 | Lexmark X5470 All-In-One InkJet Printer
IT SHOWS IN MY LEXMARK PRINTER MODEL X5470 ALL IN ONE ...xcANNOT RETRIEVE APPLICATION LIST. I NEED TO SCAN SOME DOCUMENT THATS WHY I'M LOOKING FOR LEXMARK INSTALLER FOR THIS MODEL. LOOKING FORWARD FOR...
Please follow the steps given below:
1) Click on "Start," "Programs," the Lexmark program folder, and select the "All-in-One Center."
2) Click on the "See more Scan Settings," then "Display Advanced Scan Settings."
3) Click on the "Scan" tab.
4) Click on "Edit."
5) Under "Application Name," please highlight "Microsoft Word" and click on "Add."
6) Click on "Close."
Jeethu
Sep 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
May 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
I receive code 1203 after changeing cartridge
Try the following link - http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
1. Enter your printer model
2. On the following page under "Search the KnowledgeBase" enter the text "error 1203"
3. From the results select "Troubleshooting a 1203 Error Message on the Lexmark X5450/X5470"
4. Follow the directions there and see if it solves your issue.
If not, you may want to try calling Lexmark Customer support.
Apr 27, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
71 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
