Question about Whirlpool Dryers
Whirlpool gas dryer chirps (beeps) intermittently, but runs fine. Whirlpool Gold model GGX9868JQ3. Is this a controller board?
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Posted on Nov 05, 2008
WRMtech
  • 70 Answers
SOURCE: START AND RUN PROBLEM
check the motor relay. there are 4 wires( 2 are pink and black) this goes to the coil of the relay and must show resistance(closed) you can also jump out the 2 blue wires and see it the unit keeps running. The part number for the relay is: FSP3405281 approx 40.00US
Posted on Mar 01, 2009
  • 105 Answers
SOURCE: I have a whirlpool gold gas dryer model
You either have something caught in the blower or you have a bad motor. If you unplug the dryer and pull it out. Then remove the rear panel (1/4" hex screws), looking at it from the rear, the blower is on your left. Remove the two screws that hold the blower housing on. You should be able to get your hand in far enough to see if there is something in the blower.
Posted on Apr 08, 2009
I have a whirlpool cabrio gas dryer that take along time to dry. It has a code of F1 stored on it.The dryer vent is clean.Is the control panel bad.
change gas valve coils. for f1 error, if dryer is running don't worry about it. in future if your dryer beeps and flash f1 error you can unplug dryer get main control board out check dry solder on motor control rely it it is dry solder you can solder and you good to go or not solder problem then you need new control board. good luck.
Jan 21, 2017 | Whirlpool Dryers
Dryer runs but beeps intermitenly and doesn't stop beeping
you most likely have a bad computer board located in the top console.i haven't changed any of these boards out but on the frigidaire affinity dryer this happens alot and it's the computer board.the dryer would just start beeping on it's own,like 3 beeps at a time beep beep beep,then beep beep beep,was the board,you have to give the full model number to whoever you order the board from,open the dryer door,look around the opening where you put the clothes in and you'll see a tag with the full model number.good luck.
Feb 25, 2014 | Whirlpool GEW9868K Electric Dryer
Kitchen aid gas dryer lights up but won't start
What is the model number? Look inside the door jamb.
Oct 19, 2012 | Whirlpool GEX9868J Electric Dryer
Whirlpool duet gas dryer. was working fine now all light and time amount work but will not start and beeps 3 times
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 17, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer quit heating runs fine it is a gas dryer
Is the pilot light or "stricker" working when you start the unit.. Is it getting good supply of gas?
Mar 12, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Gas duet. Mod: GGW9250PWO Ser: MR3604435. Front panel under Status: "Control Locked" light is lit..nothing else works, including Control On button. Dead. Can the dryer be reset??
is the other lights DIM(partially lit)?
If so it could be one of the following.
1.) Intermittent ribbon cables between the control board and the Interface board (one with the buttons) Reseat all four cables.
2.) faulty control board.
3.) faulty Input board.
Nov 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The dryer runs by does not ignite.
kindly check all wirings to and from the igniter assembly. does the drum turns?
Feb 08, 2008 | Whirlpool GGW9200L Gas Dryer
Dryers Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
